0-180
flr057
flr057 Posts: 20
This question has probably been answered here a hundred times but I have to ask it anyway.
What's the difference?
Which is best for movies/ music?
Should the sub be 'off' to change between 0-180?
Yamaha RX-V995
HK PA 5800
Klipsch KLF-10 (front)
Klipsch Academy (center)
Polk Rt- (rears)
SVS - PC12- NSD
Post edited by flr057 on
  • danger boy
    danger boy Posts: 15,722
    edited December 2006
    it's a phase setting.. and whichever sounds best to you.. that's the correct setting. I set mine with music that has a good bass thump to it.. and you want the bass thump in time with the music.. that's what i understand as in phase or out of phase.. you'll know when the beat is in time with the rest of the music.
    some subs have a dial.. so it's variable.. other have a 0 or 180 toggle switch.
    Doe not need to be off to swtich between 0 and 180.
    PolkFest 2012, who's going>?
  • Schwingding
    Schwingding Posts: 363
    Many people cannot detect any difference when making phase adjustments, but sometimes measuring equipment can. The adjustment control is there so that you can keep the sounds coming from the subs from cancelling out the sounds from your speakers, or other subs.
    Do you have an SPL meter?
    If so, set it up in your prime listening position. Have someone watch it while you adjust the phase control. If there is one adjustment where the SPL level increases more than the rest - leave it there. If the adjustments don't make a noticeable difference on the meter, doesn't really matter where you leave it.
    At least this is my understanding...FWIW
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
