Please help me decide
edbert
Alright, I was supposed to be getting a Pioneer VSX-816-K
from an ebay seller. Apparently there was a mixup in the warehouse and they actually didn't have more of these in stock, but they do have a Denon AVR-1507.
They said that it is a better model that they will send out to me at no additional cost. There are two major differences that I can see right away. The Pioneer is rated at 110 per channel while the Denon is only 75. The other thing is you can specifically set the surround back channels to provide bi-amping possibilities on the Pioneer.
This unit will be powering a pair of Monitor 40's, 30's and a CS1.
What should I do? Thanks for the quick help.
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
Pioneer VSX-816
CS1 - center
XBOX
SOPA since 2008
Here's my stuff.
Post edited by edbert on
if it doesn't meet your expectations.. cancel the deal and shop for the receiver that meets your expectations. don't settle.. you'll never be happy with it if you do.PolkFest 2012, who's going>?
Check this thread out.........http://www.polkaudio.com/forums/showthread.php?t=47368
I suggest you bite it............Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
