SRS 2.3's Sound Levels
westdr1
I have a pair of the 2.3's that I have finally been able to put back into action today after replacing the amp. I bought the NAD C272. I noticed the sound on the right channel to be substanially muffled in comparsion to the left. It does not appear to be distorted and I am unable to see any physical damage on any of the speakers. I noticed there were some problems mentioned on the polyswitchs. Is this characteristic of the polyswitch.
I am in the process of rebuilding the cross overs.
Any speaker cable recommendations would be appreciated. I am currently using Monster that I bought when the speakers were new.
TIA
TIA
Post edited by westdr1 on
Assuming that you have ruled out the amp as the problem,the poly's are for tweeter protection and usually reset,check your source,cables,etc. Good luckJC approves....he told me so. (F-1 nut)
george daniel wrote:Assuming that you have ruled out the amp as the problem,the poly's are for tweeter protection and usually reset,check your source,cables,etc. Good luck
George;
Thanks I will check them. -
I've heard others report the same issue, but I can't recall anyone posting a solution other than placement issues. Can you give us a description with measurements of your layout?Political Correctness'.........defined
