Adcom 5800 or the Carver 35x which one would you get ?
Deadof_knight
Deadof_knight Posts: 980
edited December 2006 in 2 Channel Audio
Im looking at both very simular in power whats the pros and cons here. Ive got a 35x and a lower model adcom 535 for my surrounds. But I need another big amp for my fronts
:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
Post edited by Deadof_knight on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I would get the Carver. Are you thinking of running some kind of mono situation or bi-amp? Remember when you mix amp brands the slew rates are likely different, for HT this never mattered much to me as there is so much going on, and I am primarily watching the movie, for music though I would not mix amp brands.
    RT1
  • Deadof_knight
    The carver is sounding better I could mono each one and get 700 watts a side for my 1.2tls Thatll be SWEET!!! great idea i didint think of that till i read your reply. See I have to buy 1 new ampanyways because I need to run an isobarrak 18" sub That would leave my yamaha available to run the sub Thanks
  • SLOCOOKN
    SLOCOOKN Posts: 704
    no bridged amps on 1.2tl. you will fry your amps and speakers. You lose common ground when bridging.
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • reeltrouble1
    You can use mono blocks with SDA as long as your present cable is a pin/blade configuration and you use the AI-1 cable. I don't have the book right here in front of me but I seem to recall the 1.2tl fit this requirement. In some cases you can ground the negative posts of each mono block amp together and be OK as well, but you need to check with the amp manufacturer for each particular amp. I recall BDT running Carver mono blocks on his SDA which are 2.3tl. There are numerous threads here you can read about it. I ran a pair of NAD 2700's bridged mono with my 1C's for quite a while with excellent results. There were some serial number 1C's that I recall where you could not run mono blocks.
    Of course you could also bi-amp the speakers to see how you liked that configuration.
    Enjoy.
    RT1
    heiney9 Posts: 25,440
    The 5800 is a powerhouse and it's a very nice detailed amp. However it is NOT common ground so the same issues will apply as mono's if you don't have the proper cable. I believe the neg grounds can be tied together but as always CHECK WITH THE MANUFACTURER.
    Either would be nice but my vote goes to the Adcom 5800 a very nice amp that performs well beyond it's price point.
