Space and budget constraints :)
richsmith61
richsmith61 Posts: 4
edited December 2006 in Speakers
I just spent less than $1000 on the following 5.1 system :D :
receiver: Onkyo TX504 [consumer reports best value]
center: CS1 [too deep for shelf]
Front L/R: Monitor 40 [amazing sound for $$]
Rear L/R: RC55i [in ceiling - don't ask :o ]
Everything is great except for the center speaker - it's too deep [think depth] for the mantle where I want to place it [under plasma]. Aside from the RM7302/RM302, all the other Polk Audio center channels won't fit :(
Now, the million $$ question: would it be really 'stoopid' to use the RM7302/RM302 with the aformentioned system? If so, what are my options.
Thanks for your help.
Post edited by richsmith61 on
    F1nut Posts: 51,717
    Can you go inwall for the center?
  • richsmith61
    I'd rather not go into the wall - I will consider it though. Also, the CS1 is a bit too tall to fit under the plasma without going flush with into the wall.
    Poor planning indeed.
    F1nut Posts: 51,717
    Ok, well I'm out of ideas, but I'm sure some of the other guys will chime in.
  • richsmith61
    Are you implying the RM7302/RM302 is not a good choice?
    F1nut Posts: 51,717
    Nope, but it's generally a good idea to stick with the same model type for the front three at least.
  • richsmith61
    My other option is to match the RM7302/RM302
    with 2 x RM6901/RM201 [front L/R] in lieu of the Monitor 40's - a bit more expensive and I think a bit less performance, judging by some of the other threads.
    I just hate to move away from the Monitor 40 speakers.
    Thanks again for the time.
