Ugh
howie777
howie777 Posts: 357
edited December 2006 in The Clubhouse
I just spent 13 hours today doing school work. My final is tomorrow, plus I have a summary to write on a 20 page article. But them I'm all done!!!!! (assuming I pass my class, which I'm hoping I do as its my last one but of course the only difficult one). Heres hoping for a B or better.
Oh and I have to make sure a couple of projects at work get finished properly tomorrow so final assembly and pictures can be taken early next week, then its off to the autoshow (detriot Jan 2007). So basically having work and school all due at the same time = really fun:eek:
Just thought I'd share
Howie
Post edited by howie777 on
  • beardog03
    beardog03 Posts: 5,550
    good luck on your finals......
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    F1nut Posts: 51,776
    Yep, good luck!
  • danger boy
    danger boy Posts: 15,722
    get crackin.. what are you doing posting here? back to your studies. :p
    PolkFest 2012, who's going>?
  • schwarcw
    schwarcw Posts: 7,358
    Are you graduating Howie? Good luck on your final!
    Carl
  • cfrizz
    cfrizz Posts: 13,415
    Focus on school & get back to studying!
    Good luck!
  • Fireman32
    Fireman32 Posts: 4,845
    Study hard. Good luck on the finals.
  • howie777
    howie777 Posts: 357
    Thanks all.
    I finished my final today. All I have left is read a 9 page paper and write a short summary and I'm finished with my Masters degree (assuming I pass this class, which I'm not 100% sure I will - need a B or better for masters). Its the only class I have had any problems with, and of course its the last one and I'm really busy at work.
    Hopefully I'll pass and be DONE!!!!!!
    Howie
  • Early B.
    Early B. Posts: 7,900
    What are you gertting your master's degree in?
    "God grooves with tubes."
  • howie777
    howie777 Posts: 357
    Its a masters in Electrical Engineering. I am mostly a software guy though.
    H
  • venomclan
    venomclan Posts: 2,467
    H
    Sounds like a lot of math. :(Best of luck.
    Venom
  • RuSsMaN
    RuSsMaN Posts: 17,986
    30 seconds of my life I'll never get back.
    Thanks for sharing. ;)
  • I-SIG
    I-SIG Posts: 2,243
    School. I don't miss it in the least. You should tell people to go to Georgia Tech instead of Hell. At least in Hell you know there will be beautiful women.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • exalted512
    exalted512 Posts: 10,735
    you can come down to my house and figure out why my internet isnt working. Ill give you $50:D
    -Cody
