Explain difference between OP-AMPS and discrete tube gain stage?
jrlouie
jrlouie Posts: 462
edited December 2006 in Electronics
I'm not even sure if I asked my question correctly in the subject of this thread. But it seems like I've heard notations comparing op-amps versus tube components that don't use op-amps.
Could anyone give me a run down at a high-level the difference and/or advantages to one setup versus the other? Or if you have a link that would do so, that's fine also.
I like what tubes bring to music and I'm just trying to learn more.
Thanks in advance for any feedback.
Post edited by jrlouie on
  • Systems
    Systems Posts: 14,872
    Basically an opamp is gain stage that can be configured in many ways and can be made up of tubes or transistors.By far the most commonly used op-amps in audio electronics is in the form of the 8 pin integrated circuit like this. http://focus.ti.com/lit/ds/symlink/opa2604.pdf
    Testing
    Testing
    Testing
  • jrlouie
    jrlouie Posts: 462
    I'm curious why some manufacturers purposefully don't use opamps. For example, the Jolida (which I'm very anxious to receive in the mail) :) Note that their very first bullet states..."Unit does not utilize op-amps".
    Then that's what sparks my curiousity about the two different approaches and their differences.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Tubes give a warmer sound then Solid State (op-amp) can. It's not to say all SS amps sound bad it's more of the design of the amp and components then anything.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • jrlouie
    jrlouie Posts: 462
    Ah, I didn't realize op-amps were solid state. There we go.
    For some reason or another I had the impression tube components had op-amps. Maybe there are some components that are "tube" components, but also have op-amps in them (kind of a mixed setup).
  • Systems
    Most inexpensive and even some expensive electronics including CD and DVD players are loaded with cheap noisy opamps in their gain stages.Manufacturers do this to keep the price of producing the product as low as possible without regards to sound quality.Their are some bad sounding opamps and thats why higher end companies don't use them.On the other hand their are some really hi performance (and more costly)opamps available that if used properly by a skilled designer can give excellent sounding results.For instance Mark Levinson uses the ones I linked to in post #2 in their mega buck preamps.
    btw.Congrats that Jolida looks like a honey of a cd player.
    Testing
    Testing
    Testing
  • disneyjoe7
    Yes an Op-amp can be made from Transistors but when did a Transistor not be classified as Solid State?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Systems
    An opamp can be made up of discrete transistors ,tubes or dozens of transistors in the form of IC.What makes it an opamp is it has a +input and a -input and an output.The pos and inverted inputs allow it to be used in different ways.
    Testing
    Testing
    Testing
  • disneyjoe7
    Ok we are talking about op-amp as a circuit design. And I was talking about op-amp as chip thing.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • schwarcw
    schwarcw Posts: 7,358
    An opamp is a small chip that as others have stated take the place of a number of other electronic components such as resistors. The enable the manufacturer to save some money and circuit board space. Some are good, some are not so good. The Jolida is a very good CDP that doesn't use them. There are other very nice high end machines that do use opamps.
    Check out the DIYaudio forum. There are people over there rolling opamps like tubes in their CDPs. As you would expect, there is a lot of debate as to which ones are better in various applications. The BB OPA2604 is an old, but still widely used opamp, it costs about $2. Others are using the OPA2134, also cost about $2 and is very good. For the past couple of years a lot of folks have proclaimed the OPA627 as the best sounding. Others have claimed the 627 has an "acquired" taste. Meaning it sounds different, maybe not better. A lot of the mod companies like Underwood HiFi, Modright, Reference Audio Mods and others proclaim the high value added by changing out the 2604's or 2134's with 2 OPA627. The 627 cost about $27, so you need $54 for each dual opamp replaced.
    The talk of "opamp tweaktown" is now the National Semiconductor LM4562. These cost about $5 and people have going wild over these. No one has these in stock yet but there are many sample out there that have found use in the DIY community and everyone is a buzz talking about the dynamics, smooth detail blah, blah, blah!!!
    I've got mine on backorder;) :D
    Carl
  • disneyjoe7
    With all this swapping going on I think they changed out to a socket for that chip swapping.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • schwarcw
    Yes! It's called a "brown dog" adaptor. Check it out HERE
    Carl
  • Systems
    Don't forget the OPA2107 at $11 a piece. Because of the price/performance ratio I use OPA 2134's,2604's and PMI's OP275 in my projects.I would like to try the 627 some time.
    Testing
    Testing
    Testing
  • jrlouie
    jrlouie Posts: 462
    I'm starting to catch the drift. Thanks for the info!
  • mlhm5
    mlhm5 Posts: 217
    All you ever needed to know and more. Start with the second one.
    http://sound.westhost.com/articles.htm
    http://www.tangentsoft.net/audio/
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Let me be very clear about this, integrated circuits
    PHOOEY. Yes I suppose 10 buck opamp trumps a 1.00 one but still not something I care much for anymore, but if it floats your boat, Rock On.
    RT1
    heiney9 Posts: 25,497
    OP amps are integrated circuits (silicon). They have many parts (which would normally be discrete components) in one small chip-set (block of silicon). While minaturization might be desireable in many applications; it's not a good idea in audio electronics that are amplifing a signal. Yes, there are cheap op-amps and there are expensive op-amps, but none IMO are anywhere near as good as a well designed discrete circuits with top notch parts. Is it more expensive to go discrete? You bet your ****, but the advantages far outweigh the costs.
    Op-amps have there place in electronics but should never be used in the signal path!
  • disneyjoe7
    RT1
    Don't worry Ted I wasn't about to break out my Soldering iron.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Early B.
    Early B. Posts: 7,900
    OK, but from a practical perspective, where can we find "affordable" (i.e., <$1K) CD players, DVD players, receivers, SS amps, etc., without op-amps?
    "God grooves with tubes."
  • jrlouie
    jrlouie Posts: 462
    Being novice to op-amps, I only know of one. The Jolida CDP (JD 100A) does not have op-amps and retails new under $1,000.
    Seeing as my current cdp is 10 years old as well as my DAC I can't help you there. My amp and pre are 20 years old. None of this equipment to the best of my knowlegde employs op-amps in the signal path.
    Op-amps have become a necessary evil in audio for their cost effectiveness as well as space savings and next to no heat output comparatively to discrete circuits and in many instances just make plain good sense. It's a tough feat to try and purchase equipment that doesn't employ op-amps in the signal path. I'm sure I'll be asking myself the same ?'s when I need to replace my current equipment.........I'm not looking forward to it.
    You just have to look a the design of a certain piece of equipment and then understand what you are gaining and losing in that design and then decide if the compromise is worth it in the overall big picture.
    Again some will care that there are op-amps some won't give a rat's a$$.
    billbillw Posts: 7,787
    Sometimes opamps are in there, even when you think they are not.
    I recently picked up a B&K Pro10 preamp.
    The literature gives this description:
    "Thank you for selecting B&K Components, Ltd.’s PRO10 preamplifier. The PRO10 is designed for the discriminating audiophile. The PRO10 is a DC coupled preamplifier that has been designed using all discrete circuit topology with a switchable head amp on the phono stage. Gold-plated premium connectors have also been utilized to minimize degradation in the signal path. The PRO10 has an external power supply that should be connected to an unswitched AC source. In order to obtain maximum performance from this unit, Please read these instructions very carefully."
    I opened it up and had a look. Low and behold, I found 4 opamps on the board. Albiet, they were good ones, and they are mounted in sockets for easy replacement (haven't yet checked to see what upgrades are available if any).
    When I looked closer in the literature, there was a line that followed the above description:
    Also:
    Direct output capability
    All discrete predriver circuitry
    Premium gold-plated connectors
    Separate source and record selectors
    Balanced outputs standard
    So, it can be deceiving. The preamp sounds damn fine to me, regardless of the opamps. They have mostly gotten a bad rep from their overuse and cheap implementation.
    EDIT: I should have mentioned, by looking at the board, I believe that two of the opamps are used for the MC phono gain, and the other two are used in the linestage, only in active mode. So, I should be opamp free when in passive mode, with a MM cart.
  • Systems
    Big improvements have been made in IC Opamps the last few years in the areas such as lower noise and distortion ,faster slew rates ,wider bandwidths etc.The newer hi performance opamps are actually light years ahead of the ones produced in the 70's and 80's and in the hands of a skilled engineer can be made to sound as good as discrete circuits.For instance some of the DIY designs by noted Opamp guru Walt Jung sound marvelous.Even Mark Levinsons ultra expensive preamps use them in the signal path.So yes while the cheap Opamps littering the insides of inexpensive components made in the Far East can sound pretty nasty, the better ones implimented properly with good power supplies etc,can sound very good indeed.
    Testing
    Testing
    Testing
