My New Sub
harold280z
harold280z Posts: 72
Martin Logan Dynamo, this thing really rocks very tight bass! I had the PSW10
was a good sub but I wanted a sub that had more punch. Take a look!
http://www.polkaudio.com/forums/showcase/closeup.php?userid=73547&pic=331_27_big.jpg
My system for the bedroom
Pioneer Elite A/V Receiver VSX82TXS
Pioneer Elite DVD DV-46AV
Sony Bravia KDL-40S2400
Polk RTi8's front
Polk RM 202 center
Polk T20E rears
Martin Logan Dynamo Sub
Bedroom Stuff 5.1
Pioneer Elite VSX-82TXS
Pioneer Elite Blue Ray BDP-05FD
Monster Power HTS3500
Harmont Remote 880
Sony Bravia KDL40S2400
Polk RTi8's Front
Polk T20E's Rear
Polk RM202 Center
Martin Logan Abyss Sub:D :D ::D
Basement Stuff 7.1
Sony STR ES5000
Sony DVD NC55ES
Pioneer Elite DVD DV48AV
Pioneer Elite 910HD
Monster Power HTS3600
Harmony Remote 688
Warfedale Diamond 8.4 Front
Warfedale Diamond 8.2 Sides & Rear
Warfedale Diamond 8 Center
SVS PB12-Plus/2 Sub:D:D :D
Post edited by harold280z on
  • polrbehr
    polrbehr Posts: 2,857
    edited December 2006
    Very nice setup! That's gotta sound great. How big is the room?
    I especially like the archway in the B/R with the single mini-hat.
    How long did it take to find a dresser that would fit like that?! :)
    Older home? I noticed the exposed radiator under the window .
  • harold280z
    Thanks for the look! Really sounds great! My home was built in the 30's the bed room is apx 10ft wide 15 feet deep. That's a built in unit in the arch way. Take a look in showcase systems under my user name. Check out the basement major sounds there!
    Bedroom Stuff 5.1
    Harmont Remote 880
    Polk RTi8's Front
    Polk T20E's Rear
    Polk RM202 Center
    Basement Stuff 7.1
    Sony STR ES5000
    Sony DVD NC55ES
    Pioneer Elite 910HD
    Harmony Remote 688
  • polrbehr
    I did - the basement looks good as well!
    I especially like the custom work on the built-in in the B/R.
    I was thinking of upgrading my R50s to RTi's some day... either 8s or 10s; still not sure.
    But, a better sub (SVS, if $$$ permits) will probably come first.
