Bi Amping and Sub hook up
VXR8
VXR8 Posts: 291
Hi guys,
I tonight have bi-amped my RTi10s and am pleased with the result, but I want to understand the impact of bi-amping and still utilising my existing connections to my PSW505, via the speaker inputs and outputs on the sub?
I believe the second connection I have made from my amp is to the high frequency connections on the speakers (top connections) whilst my original "main speaker" connections, which are running through the sub, are connected to the lower connections, which I also believe to be the low frequency for the RTi10s.
Is this the ideal connection now? I was happy when the high and low frequencies were bridged and my above connection type, but just want to make sure this is still the case or if I need to change my connection some how.
Thanks in advance.
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
Post edited by VXR8 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited December 2006
    VRX8,
    I believe is that any Sub with speaker inputs and RCA LFE input is using the internal amplifier of the sub. The speaker input is working as you wired the sub as LFE input. This way is not best as you're adding noise to the sub signal, best to wire to LFE if you're AVR serves it.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • VXR8
    VXR8 Posts: 291
    Thanks Steve,
    The Yammie does have the LFE, so I'll give that a try. The sub certainly works more effectively via my current connection (as per Polk suggestion in their education section of this site), but the LFE may now come into its own now that I have bi-amped.
    Thanks again.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • disneyjoe7
    Are looking at this http://www.polkaudio.com/education/article.php?id=19
    I'm in agreement with the Polk Gods.
    If you're using the sub in 2 channel mode (music) then I say ok, but with bi-amping amps it doesn't matter which amp you use for this propose. What ever sounds best but only one amp not both.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • VXR8
    VXR8 Posts: 291
    Yes, that was the article that I was basing my decision on and I also listen to music quite regularly, not only home theatre. The unfortunate part when I tested the new set up today, I couldn't utilise a lot of volume (wife was asleep at the time). I'll try again at louder volume tomorrow and either leave it as is, tweak it a bit or try the LFE option. I used to hook up via the sub out on the AVR (previous models as well), but found I was lacking with 2 channel and follwed the Polk Gods directions ever since.
    Thanks again for responding so promptly.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • polktiger
    polktiger Posts: 556
    I am still learning new stuff on my AVR, but my Yamaha permits me to direct bass to sub only, fronts only or both sub and fronts. Does the 2700 not do this? I may be missing something with mine.
  • VXR8
    VXR8 Posts: 291
    edited January 2007
    Hi Polktiger,
    Sorry for the delayed response. Yes, the 2700 does have that option too but you would be required to set your main speakers to "small" to get the sub to work when you select "both" in the receiver menu. If you set them to large as I have, in 2 channel mode the sub doesn't get the signal to turn on. Likewise, if you select "Pure Direct" the sub is eliminated. By hooking up the main speakers through the sub, the sub always receives a signal, no matter what the setting is.
    Hope this helps
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
