Sony turntable question?
dagame27
dagame27 Posts: 599
edited December 2006 in 2 Channel Audio
Hey guys, I was given an old Sony ps-x45 turntable and a bunch of old vinyl. I am planning to buy a tube pre with a phono stage. I understand that this model needs some kind of "step-up amp" or something. I have no idea what I am looking for. Does anyone here have any idea of where I can find one of these or if they are even necessary on newer pre-amps. Thanks
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
  • shack
    shack Posts: 11,154
    I think you are referring to a step-up transformer. This is usually to allow a MC (moving coil) cartridge to be used with a phono preamp (or receiver/integrated amp with a built in phono preamp) set up to work with a MM (moving magnet) cartridge. I could be wrong but I would be supprised if that table has a MC cartridge. If it is indeed a MC cartridge you would simply need a phono preamp that will work with either one where there typically will be a switch to select the type.
    Here is a pretty good primer on the difference between the two.
    Moving Magnet Vs. Moving Coil
    There are two primary methods a modern cartridge uses to generate current. These are moving magnet (MM) and moving coil (MC) configurations. Many moving coil cartridges come in high and low output versions. In order to better understand the differences between the two it is necessary to briefly discuss methods of generating electricity, as well as provide you, the reader, an amusing anecdote about my youth.
    Let's travel back in time together to science class. My 8th grade science teacher delighted in demonstrating to us a small hand cranked generator. In hindsight his methods were quite masochistic. He would line us up and eloquently explain the wonders of electricity by giving each of us a mild shock. After all of our fingers were zapped, and he had briefly made each of us accountable for being disinterested in science class, our status quo arrangement of politely ignoring one another resumed. I did however develop a rudimentary knowledge of electricity, as well as a distrust of science teachers, that I retain to this day.
    Basically moving magnet cartridges works in the same way as that, or any other generator. By moving a magnet within copper coils a small voltage is created. It breaks down like this:
    As your stylus tracks in the groove of a record it picks up vibrations. The grooves of most records are oriented to produce two separate (right and left) signals. Vibrations from the stylus are transferred up the cantilever to small magnets. The magnets are oriented within metal poles that extend from fixed wire coils, as the magnet vibrates a small voltage is created. The voltage travels from your cartridge to an amplifier and suddenly you're listening to Paul Stanley espousing his desire to "rock and roll all night, and party ev-er-y day."
    Moving magnet cartridges tend to produce lush, mellow sound. They are available in a variety of shapes, sizes and levels of quality. Most MM cartridges have replaceable styli. Their high voltage output, variety, and the availability of stylus replacement make Moving Magnet cartridges a great choice for the beginner and audiophile alike.
    Right about now your probably asking, "Brian, if moving magnet cartridges are so great then why do they make Moving Coil Cartridges too?"
    For you, gentle reader, I will attempt to explain:
    Moving Coil (MC) cartridges work in a similar way to MM cartridges. The primary difference being, as your stylus tracks it vibrates tiny wire coils around a magnet. Many audiophiles prefer moving coil setups. MC cartridges tend to display better tonality, transparency, imaging, and also tend to create less distortion than their MM counterparts.
    A moving coil setup requires much more consideration for you system, as well as a familiarity with audio component setup. Moving coil cartridges are not always the best idea for a beginner. Many MC cartridges will not work in pre-amps designed for MM cartridges. Modern receivers often do not have an input for turntables (this section is usually labeled "Phono"), if your receiver does not have this feature you will need a separate pre-amp to drive your turntable, and an open auxilary plug-in. If your modern, or vintage receiver does have this section you will need to know if it is configured for MM or MC. If the unit is not clearly labeled your manual will provide you with specifications. Some receivers have a switch built in (usually near the RCA plug-in for your table) that can dive either MM or MC, this is rare but not unheard of, especially in high-end audio components.
    Many manufactures produce high and low output versions of the same cartridge. Benz Micro for example produces the Benz Gold (0.4 millivolts) and Benz Silver (2.0millivolts) thought they have different names and are different colors they are, save the output voltage, the same cartridge. Other manufactures produce both high and low output cartridges that are dramatically different from one another. High output MC cartridges can usually be used with pre-amps configured for MM setups.
    If you have no existing preamp your options are limitless. You will simply need a versatile preamp capable of being set to your cartridges specifications, such as the Lehman Black Cube, and the cartridge of you choice MM or MC, the world is your oyster.
    If you have an existing moving magnet pre-amp (separate from or integrated into your receiver), or your budget precludes an MC pre-amp, you can chose between any MM cartridge or a high output MC such as the Orotofon X MC series.
    If you are determined to run a low output cartridge but don't want to change your existing MM pre-amp; step-up transformers such as the Ear MC3 are available.
  • shack
    shack Posts: 11,154
    Another option to a step-up transformer or switchable phono preamp would be to change the cartridge to a MM type.
  • dagame27
    dagame27 Posts: 599
    Thanks Shack, it is a MC cartridge in the turntable. My father put an Onkyo cartridge in a while back. So it sounds like I need a preamp that can do either mc or mm, as well as handle a low output mc. I guess its back to research.
  • dagame27
    dagame27 Posts: 599
    Thanks for the help Shack, I got it running with an old sony reciever that we had lying around. It will do until I find a tube pre for my system.
