how to hookup dvc 4 ohm sub into box???
i have a dvc 4 ohm sub so it will be wired into 2 ohm. Im getting a mono block amp thats 2 ohm stable. so inside the box how do i connect the speaker wire to the sub? connect positive coil to positive coil and negative coil to negative coil and then connect negative one one coil to box terminal and one positive coil to box terminal making sure the positive and negative are from seaperate voice coils?
Post edited by jazjenal on
all you need is parallel connection first hook the postive coils together on the sub then do the negatives. now take the positive to the + on the amp and the negative to the - and youll be good to go as long as the amp can handle 2 ohm stable:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
