JOLIDA JD-100 CD Player
dorokusai
Jolida JD-100 Tube CD player - Silver - 9/10 - *SOLD* to JRLOUIE
I stumbled across another one and have no use for it in-house. I was told it was low hours but when I unboxed it, the plastic wrap on the faceplate was still in place. I had pull it away to test it for operation, but it's back on and the unit looks brand new to me. I'm listing it as 9/10 because the box didn't come sealed.
What can I say, it's got a huge following in the audiophile community and F1Nut performed probably the most over the top, balls to the wall mod ever created to his stock Jolida player a month or so ago....with great results from what I've read.
It's currently bone stock and ready for your consumption. I can only comment on what I've heard @ Polkfest and Jesse's house ages ago and this is definetly a very nice CDP. The Polkfest demo was stellar but so was everything in the audio chain. As soon as you stumbled out of the love nest, you ran into a CDP heavyweight, Musical Fidelity Tri-Vista. It was absolute torture to listen to all that good stuff down there
If you're undecided about whether a tube CDP makes sense, this will put you in a real dilehma. I'm sure that enough positive reviews of this player can readily be found on the internet.
As usual, all connections have been cleaned and treated with CAIG products.
Construction Details and Features:
Gain stage utilizing two 12AX7A vacuum tubes. Unit does not utilize op-amps.
Two transformers.
24/96 Burr Brown DAC.
Phillips CDM 12 Transport System.
Programmable for up to twenty-four tracks.
Full - function random access metal remote control with search function.
Track repeat and index of track search function.
Variable Headphone output.
Technical Specifications:
Frequency Response: + 0.5dB, 20Hz to 20KHz
S/N Signal to Noise Ratio: > 102dB
THD + N Distortion: < 0.01%, 1KHz
Channel Separation: > 96dB (1KHz)
Line Output Voltage: > 2V, 47 Kohms
Digital Output: 0.5Vpp, 75 ohms
Headphone Output: 35 mW, 32 ohms
Power: 110V or 220V AC 50Hz/60Hz
Power Consumption: 20 watts
Size: 17 in. wide by 12 in. deep and 3.5 in. high
Weight: 22 pounds
*I'm told that an immediate tube replacement is suggested for the stock compliment...so buy your Ei Elite now and have some tube rolling fun.
www.jolida.com
Jolida JD-100
Includes: Everything. The only non-stock item is the Ziplock bag that contains the power cord, which is also brand new
If you need ANY additional information, contact me directly dorokusai@comcast.net
Thanks for reading.
JJD100620
Two transformers.
Weight: 22 pounds
www.jolida.com
Jolida JD-100
Thanks for reading.
JJD100620
Post edited by dorokusai on
I know jrlouie has expressed interest via email so keep that in mind but I wanted to get this posted so it was a public transaction anyways.
Another Jolida component is on the way.... a JD-1301 Integrated Amplifier.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
this is a great buy folks..!
If I had coinage right now I would be all over it...and I already have one !
I still want it....I know ...it`s a sickness
Great price , great guy..
Buy it before I do...no **** !Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
I can use another one if jrlouie passes. Call it a second dibs :-)
-fredv- -
email sent
At that price, this is clearly another "karma".... you are being very generous....probably because you were a really bad boy the whole year_________________________________________________
Thanks for the comments and interest guys
The CDP looks to be going to jrlouie....woo hoo!CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
