Craigsub rankings thread
Schwingding
This was taken by me from AVSforum, where it was originally taken from AVS123.
This was taken fron AV123 boards, it is GOLD imo and deserving of it's own thread. Bravo Craig!
1. JL Audio Fathom 113: 103 points.
2. Velodyne DD-18: 100 points.
3. ACI Maestro: 97 points.
4. JL Audio Fathom 112: 95 points.
5. Hsu VTF-3 HO + Turbo: 94 points
5a. Hsu VTF-3 HO w/o Turbo: 92 points
6. SVS PB12-Ultra: 90 points.
6T. Axiom EP-500: 90 points
7. SVS PB12-Plus/2: 87 points.
8. Rocket UFW-12: 85 points (provisional)
9. Rocket X-Sub: 78 points
10. Rocket Tyke: 60 points
As you can see, the "least performing" subwoofer still delivers 60 points. The Tyke really cannot deliver subwoofer performance. It still will add foundation to bookshelf speakers, and is a pretty good barometer for the entry level sub.
The Axiom EP-500 and the PB12-Ultra are virtual ties. The Axiom is a little more articulate, while the Ultra yields an extra 1/2 octave deeper.
The UFW-12 is the original version, and is only limited due to the fact it only manages 25 Hz. MLS mentioned getting me the upgraded driver/amp package. So, as with the Hsu, the rating is a provisional one.
For the scale, I consider 75 to be about the point in which a subwoofer is having a major beneficial impact on the overall system ... and the X-sub qualifies for that distinction.
Also ... Later the Hsu VTF-3 HO and the MBM-12 will be tested as a $1500 subwoofer, which will be the price for both, including the Turbo.
When evaluating these subs, I wanted to develop a system which would be easy to follow ... yet allow for a HUGE difference in the performance between, say, a TYKE and a Fathom 113.
In a direct linear fashion, the Tyke might look like it is 58.25% the sub the 113 is. Of course, it is not.
How the scaling works is this: each 3 points represents a 15% higher level of overall performance. It is also cumulative.
For example, The Fathom 113 is 43 points higher than the TYKE. Grab a calculator, and you will see you have 14.33 consecutive 15% improvements.
Take 1.15 x 1, and do it 14 times, and you get 7.08. Next, multiply 7.075 x 1.05, and you get 7.43.
In other words, the Fathom has 743% higher performance than does the Tyke.
The Hsu VTF-3 HO W/Turbo has 38.9% higher performance than does the SVS PB12-Plus/2 (in this case, the overall musicality added to extension wins the day).
The Fathom 113 has 46.5% higher performance than does the 112.
As an aside, to keep this from being overcomplicated, each single point outside the 3 point criteria is scored at 1.05, not according to a true scale, which would be 1.0477.
HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee
Yamaha 5990 AVR
Onix SP3 tube amp
Polk CSi5 center
Bedroom rig
Onix Ref 1 monitors
Velodyne minivee
The AV123 person spent a lot of time explaining how the scaling works, that +/- 3 points is statistically insignificant, etc.
But there is NO explanation of the most important calculation: how the number of points were derived. Was it by another formula based on specs or maybe independent measurements, or just a number arbitrarily assigned by the reviewer? -
Here is the relevant thread
http://www.avsforum.com/avs-vb/showthread.php?t=768150
The author is over there - ask him, he is being very helpful with queries about his process.HT/music rig
Yamaha 5990 AVR
Onix SP3 tube amp
Polk CSi5 center
Bedroom rig
Onix Ref 1 monitors
Velodyne minivee
