Problem with TV?
Home Theatre
I have a Mitsubishi from 2001. Here is the problem when i watch HDTV
on DTV 1080I the colors have a kind of grey tint to them. If I watch it on 480I the colors are fine, but then I have the grey lines. Is it the tv or the cable? Any help would be great. I am actually selling the tv to someone who I think is getting regular cable.
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
Possible source, do you have another source to try? I don't think is a TV problem, if other pictures are ok.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Even the wife said it had a grey tint to it.Everything I own burned in the fire!!!!!!!!!!
I'm not saying you not see Grey, but I don't think it's the TV (but maybe I wrong). Ok so how are you getting HDTV? Cable you say cable box or just cable? Does the TV have a HDTV tuner or just a HD input?
We could to rule out any other troubles first.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I would say its the cable box. I'm having a problem with the audio where I get a loud popping sound when i change channels or goes to commercial. I have replaced the cables so my next step is the box. I would try this first hope this helps.
disneyjoe7 wrote:I'm not saying you not see Grey, but I don't think it's the TV (but maybe I wrong). Ok so how are you getting HDTV? Cable you say cable box or just cable? Does the TV have a HDTV tuner or just a HD input?
I am getting the HDTV through a cable box. I think it is probably just a hd input.Everything I own burned in the fire!!!!!!!!!! -
I'm with Fireman on this feeling it's the Cable Box, unless you need a reason to upgrade set? Then Hell Yes it's the TV.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
i'd post this at hdguru dot com and see what he says
