vmps sub to be or not to be?
SLOCOOKN
SLOCOOKN Posts: 704
I currently have a spl 1000 series 2..I have a friend who won't leave me alone about selling it to him. So my consideration might be an svs or vmps. I am aware that they are both non-powered. I have an extra adcom 555 mk 2 and a carver tfm 55x to power either...user reviews welcome...60% movies 40% music. that being stated Music side is more for me so more like 50/50 imho:)
:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
Sony cx985v (for now)
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
AudioQuest Crystal 2 spk wire
Nordost RCA
SDA 3.1 tl RD0 tweets
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
VMPS Original Tall Boy (Mega Woofers soon)
Post edited by SLOCOOKN on
  • Early B.
    Early B. Posts: 7,900
    edited December 2006
    VMPS for movies and music, definitely.
    "God grooves with tubes."
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    QUESTION...I sold the velo. I am entertaining the idea of a VMPS larger..mega upgrade.1.)Would it be better to get a plate amp or use the extra adcom gfa 555 mk2 to power it 2.) If so what other equipment should I consider..my pre amp has a filter at 80 hz..Passive or active crossover (Audio Control etc..)..any suggestions?
    Thanks,
    Steve
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Early B.
    edited January 2007
    The answer depends on how you plan to use the sub.
    For HT, I'm using the receiver to crossover my sub (with separate amp) at 80 Hz. That's it. I don't use a sub for music, but if I did, I'd want to get an external crossover -- maybe a Paradigm X-30.
    A plate amp makes it simpler and less expensive, but the tradeoff is a slightly lower sound quality. Your Adcom would be nice. If you're pursuing a VMPS sub, because of its superior SQ, I wouldn't screw around with a plate amp.
    FWIW, VMPS subs can now be ordered with plate amps. Same ones as sold at Parts Express.
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    I would be using it for both music and ht. I was wondering about an audio control richter scale or other active vs. passive. I am aware of a minimalist approach and the passive is less steps. but the AC has an analizer to help make adjustments...What are your thoughts.
    Thanks,
    Steve
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Early B.
    edited January 2007
    If you're gonna get fancy, I'd suggest getting a digital equalization system such as the Onix R-DES. Works great.
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    I looked in the swap and found where one was sold...Hmmmm I just might have to check that out. Thanks again.
    One more question. There are two posts. should I bridge the amp and use a good jumper or use right and left channels. My pre has 2 outputs for subs. One is lfe set at 80 hrz. How would I make the connections
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    This might sound a little cavemanish'. I do not have a computer in my house so this is not an option. Any other suggestions.
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Early B.
    edited January 2007
    Try it both ways -- bridged or unbridged. Try it bridged if your driver is 8 ohms. Sometimes a bridged amp doesn't sound as good. Since the woofer in my DIY sub is 4 ohms, I use a single channel on a 2-channel amp. Works great. However, you'll need to ask Brian at VMPS the minimum power requirements, but I think you'll be fine.
    But if you've got 2 outputs for subs on your preamp, I believe you can hook up the two active VMPS drivers separately with a 2-channel amp. This scenario would probably be the best option. Again, ask Brian about it.
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Sounds Great. I will call him tomorrow. I spoke with him once already. He is a real nice guy. Thanks for the advise it is always appreciated!
    Thanks,
    Steve
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    I now have my sub. This thing is almost as big as my 3.1's. The wife dosen't know about it yet!!! She gets home before me so I hope it will be there when I get home tonight. All I need is four cables or 2 pairs to hook the sub up. I decided to go with room treatments and no EQ. So if anyone has 2 pairs of spk cables they would like to get rid of please let me know.
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Early B.
    edited January 2007
    Great. Post pics here.
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    I will do that, mabey tonight...... IF I SURVIVE :)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
