New Gallo Reference 5LS Prototype
RuSsMaN
RuSsMaN Posts: 17,986
edited December 2006 in Speakers
Post edited by RuSsMaN on
    F1nut Posts: 51,686
    Hmmmm....me like!!!
  • Joey_V
    Joey_V Posts: 8,600
    Daaaang...
  • ESavinon
    ESavinon Posts: 3,067
    Wow! I'm in love!
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • wingnut4772
    wingnut4772 Posts: 7,519
    Yeah..try getting that by your wives.:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • unc2701
    unc2701 Posts: 3,587
    holy crap. I just don't get how he could get any bass out of those 4" woofers- unless they've got a crazy low Fs, it doesn't matter how many there are.
    Backburner:Krell KAV-300i
  • jdhdiggs
    jdhdiggs Posts: 4,305
    Fs be damned, they don't have the displacement to do it. 12 4"'s would be equivelent to a low to midrange 8" driver.
    That said, that thing looks nice...
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • RuSsMaN
    Based on what calculation James?
    http://www.epiphanyaudio.com/products.html
    4 inch drivers that I've heard in person, solid into the low 30's.
  • jdhdiggs
    Geometry - Surface area times throw.
    In bass - No replacement for displacement
    There are 8" drivers that by themselves are solid into the low 30's as well...
    Those 12 4" drivers have at best a 0.5" throw. That equates to an 8" driver with a 1.5" throw which is fairly common today. Each setup would have 96PI in^3 displacement. Now the 4"s will probably sound much better and blend better into a room than the 8.
  • unc2701
    eh... it's a balancing act, but displacement has a lot more to do with SPL than your final -3db point. Move the xmax down and you just get a parallel line at lower SPL. Lower the Fs and you get a lower -3db.
    I'm assuming that there's no correction circuit involved to boost that bottom end.
    Regardless, Gallo clearly knows his **** & I can't wait to get those Ref 3's into my listening room.
  • Joey_V
    Joey_V Posts: 8,600
    Exactly, if Gallo didnt know how to design speakers, he wouldnt have made it this far in the speaker business.
    Just wait and listen.
    Joey
  • dkg999
    dkg999 Posts: 5,647
    Wingynut - what wife:D The GF has already resigned herself to the den and half the basement being off-limits should we ever attempt the same address thing.
    Cool looking speakers. I would love to spend some time listening to them!
    DKG999
  • RuSsMaN
    All things equal, with FLAT drivers, maybe the equation would hold water. It's not simply the diameter, but the cone depth and shape also. You have no idea what the xmax of the drivers are. Easy examples at the links below:
    http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=264-846
    3mm Xmax.
    http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=264-828 (similar to what the Epiphany's use)
    4mm Xmax.
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=296-145
    2.7mm Xmax.
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=297-010
    3mm Xmax.
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=297-434
    3mm Xmax.
    ...and so on, you get the drift.
    With proper cabinet design, and multiple drivers, you can get the tuning frequency VERY low. That's why people that like line arrays LIKE line arrays. You can acheive full range, musical bass, with multiple small, fast drivers.
    Cheers,
    Russ
