CS1000p on eBay
RichCanDo
RichCanDo Posts: 177
edited December 2006 in Vintage Speakers
Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
Pre-amp: DBX CX1
Center: CS1000p Rear Surr.; f/x1000
Parasound HCA-1205A amp; Center & rear
Sub: SVS PB12-Ultra
DVD: Denon 3910
Tuner, FM: Onkyo Integra T-9090II
Cassette: Onkyo Integra TA-2090
VCRs: JVC HD4000U digital, HRS8000U SVHS
Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
Conditioning: Monster AVS2000, HTS5100MKII
Post edited by RichCanDo on
  • BMc
    BMc Posts: 35
    How do you like yours? I noticed you also have separate sub in a system that includes the SDA 1.2TL's and the CS1000P with powered subwoofers.
    Are you using the LINE IN (sub woofer only) input on CS1000P?
    Sony KF-50WE610 LCD Projection TV
    Dish 411 HD satellite receiver
    Arcam AVR 300 Receiver
    NAD 502 CD Player
    Toshiba DVD SD-3800
    front: Polk 3.1TL w/ RD0198-1 tweeter
    center: Polk CS350-LS
    surrounds: Polk Monitor 7C
    channels 6 + 7 set to biamp front
  • RichCanDo
    Mine has not been used much. Much of system is torn apart. Obtained the CS1000p about 6 months ago and not yet connected it to see if it even works. Went to connect it and the amp I planned to use keeps blowing main fuse.
    The 1.2TL's were an eBay purchase. The SDA does not seem to be working, but not had time to set up and adjust properly. From what I do hear, I prefer the original SDA SRS's I had. The 1.2s have plenty of bass by themselves. Have them both against side walls (actually a wall and a closet) in a narrow room which makes them boomy, so have the bass turned down some. Maybe SDA does not work because speakers are against side walls.
    The SVS sub seems great with movies, but again, still not set up properly. Want to upgrade, looking for an Anthem AVM 40 or 50 at a good price and may buy the Earthquake Cinenova 5 channel amp. Use 4 channels to biamp the 1.2TL's and the fifth channel for center. Use my 4ch DBX amp for the surrounds.
    Pre-amp: DBX CX1
    Sub: SVS PB12-Ultra
    DVD: Denon 3910
