Removing super glue
cindy100
cindy100 Posts: 256
edited December 2006 in The Clubhouse
Any tips for getting super glue off your skin and counter top? Once it spilled, I thought I got it all cleaned off but… Thanks!
Cindy
Post edited by cindy100 on
  • dkg999
    dkg999 Posts: 5,647
    Try acetone, which some nail polish removers have in them.
    DKG999
  • unc2701
    unc2701 Posts: 3,587
    If you didn't glue anything to your skin, don't worry about getting off. When I used to play bass a lot, i'd put superglue on my fingers & spread it around to keep my skin from peeling off (the trick was to not glue your fingers to each other). It'll come off in a day or two.
    Backburner:Krell KAV-300i
  • RuSsMaN
    RuSsMaN Posts: 17,986
    dkg999 wrote:
    Try acetone.
    DING!
  • hearingimpared
    hearingimpared Posts: 21,136
    ACETONE will take it off anything. Just make sure you don't take the finish off something else.
