Recommend source for banana plugs
I've been playing with upgrades lately so taking on/off the speaker wires are becoming a chore. I want to upgrade my connection to banana plugs.
Any recommendation on a good source of decent quality plugs while not being super expensive? I need about 20 pieces.
Thanks.
Thanks.
Post edited by ivansfo on
http://www.speakerrepair.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=BL10&Category_Code=AHH_Banana
They are a quality product without the high price."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
pearsall001 wrote:http://www.speakerrepair.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=BL10&Category_Code=AHH_Banana
Phil how are mine coming along with the jumpers????:) -
These won't short out in the back (non conductive). Also, they are quick and easy to use...
http://www.amazon.com/gp/product/B00005U21H/ref=pd_cp_e_title/002-8831043-5942436
I just got them and they work great. -
Parts Express
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=091-330
The "floating slug" adds even more contact area... sometimes a concern with nanners.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Wow...these are some real nice plugs. Thanks for all the suggestions.
I'll think I'll just order a set from the cheapest of the bunch. Still will run me about $40 for the set.
Thanks all. -
Ive used these...
http://cgi.ebay.com/8-NAKAMICHI-Gold-plate-Audio-Banana-Speaker-Plug_W0QQitemZ320061707459QQihZ011QQcategoryZ32838QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Easy to install, cheap, pretty tight, and look great.Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
