should I bother with interconnects
phipiper10
I thought I was sure of my self on some of this stuff but now I'm not so sure.
I have a Pioneer DVD (below) which is currently serving as my CDP too. That said I have an audioquest digital coax from DVD/CDP to my TX-NR901 which serves a pre/pro.
I have the Rotel listed below which serves as amp for 2 channel and to power the mains when I have the home theater on, surrounds/center run off Onkyo.
My question is this; Is there any reason to put interconnects between the DVD/CD player since I prefer the DAC in the onk over that in the DVD/CDP?
Let me know if I'm misunderstanding either the analog vs. digital deal hear or with cables vs DACS.
If I were to get a used cd player in the $300-$500 range and then I use digital coax to the onkyo aren't I paying a bunch of that $300-$500 for the Dacs in the CDP which I won't be using (until I get rich and get a new 5/7 channel amp right???)
I've been away a while but the bug is creeping back, I'm trying to ease in with some cables or speaker wire to take the next step up.
Thanks,
Rich
Thanks,
Rich
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
The DACs in most "good" CD and DVD players are typically better than the ones found in an AVR. It also depends on what you are looking for. For DVDs I ususally just use a digital path and let the AVR do the decoding. It's just easier. For music I always use the CDP or DVD player's DAC with an analog interconnect.My question is this; Is there any reason to put interconnects between the DVD/CD player since I prefer the DAC in the onk over that in the DVD/CDP?
How do you know this? Have you actully put a quality pair of interconnects into the mix and A/B between the analog input to the receiver vs the digital? I have and I have yet to hear an AVR's DAC that outperforms the DACs of my various sources. Once you do that and decide which is the better sound...you have your answer."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Well your question was the right one! I did do some A/Bing but it was with some crappy cable serving as IC vs the audioquest coax. I'll try again with some real IC and see what happens. I guess the results I found originally which pointed to the Onk's DAC's being better was really comparing (rotten) apples to juicy oranges oranges. Thanks for stating the obvious, it's helpful. I'll try again with fresh fruit!Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
I was curious about this as well and I checked the specs on my AVR and DVD; both indicate 192/24 for the DACs; I am guessing since both AVR and DVD are Yamaha that they are using the same DACs (RX-V2500 & DVD-C750)
