Subs
harold280z
harold280z Posts: 72
edited December 2006 in Speakers
Looking for a new sub for my bedroom I now have a polk PSW10 sounds just a little weak no punch. I like my bass tight, clean & loud. I'd like a sub with a small footprint.I'm thinking that maybe the Velodyne SPL 1000 or Velodyne Mini Vee will work.Giving me more punch. I'm looking for some options.My room size 12x18 my current system is :
My set up is the following
Bedroom sounds!
Pioneer Elite Receiver VSX82TXS
Pioneer Elite DVD DV-46AV
Sony Bravia 40XBR1
Motorola DCT-6412 Digital Cable Box With DVR
Polk RTi 8's front
Polk T20e rear
Polk RM 202 center
Polk PSW 10 sub
Bedroom Stuff 5.1
Pioneer Elite VSX-82TXS
Pioneer Elite Blue Ray BDP-05FD
Monster Power HTS3500
Harmont Remote 880
Sony Bravia KDL40S2400
Polk RTi8's Front
Polk T20E's Rear
Polk RM202 Center
Martin Logan Abyss Sub:D :D ::D
Basement Stuff 7.1
Sony STR ES5000
Sony DVD NC55ES
Pioneer Elite DVD DV48AV
Pioneer Elite 910HD
Monster Power HTS3600
Harmony Remote 688
Warfedale Diamond 8.4 Front
Warfedale Diamond 8.2 Sides & Rear
Warfedale Diamond 8 Center
SVS PB12-Plus/2 Sub:D:D :D
Post edited by harold280z on
  • SLOCOOKN
    SLOCOOKN Posts: 704
    harold I have a vel spl 1000 series 2. i am running an aq sub 3 cable...lfe from avr to lfe to vel in sounds great with no problems..you might look at raymond cables for sub cable. it is made in usa, aq's were not i was dissapointed in this..
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • harold280z
    Thanks for the input. That Mimi Vee looks to me in my price range. Might still go up to the spl 1000 if I can get a good deal. I'm running the sub on coaxle, long run inside a wall.
    Bedroom Stuff 5.1
    Harmont Remote 880
    Polk RTi8's Front
    Polk T20E's Rear
    Polk RM202 Center
    Basement Stuff 7.1
    Sony STR ES5000
    Sony DVD NC55ES
    Pioneer Elite 910HD
    Harmony Remote 688
  • Schwingding
    Schwingding Posts: 363
    I have one question: Why would you buy a "SUB"woofer that only goes down to 28Hz? That is the published lower extension on the minivee.
    For the same price you can get a number of SVS subs with much greater range, and output. Call Erik at SVS and discuss your requirements with him.
    FWIW, I have both a Minivee and a couple of SVS subs. The one thing I don't like about the minivee is the auto-on doesn't kick in as early as I'd like. It is a nice little sub, but it doesn't go down into real sub territory.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • Pepi28
    Pepi28 Posts: 248
    Go for the new svs sb12 sub. I am thinking about getting it as an upgrade for my bedroom system. Kicks mini vees ****.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • MSALLA
    MSALLA Posts: 1,602
    I don't think any SVS ahs a small foot print. Do they?
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Grimster74
    Grimster74 Posts: 2,576
    The new SB12 has a foot print of only 15" x 14" x 14" and only weighs 40lbs.
  • SLOCOOKN
    SLOCOOKN Posts: 704
    I have been considering changing my subs around. I have the spl1000 2. I have no where to listen to the svs..any comparison?
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Ron Temple
    Ron Temple Posts: 3,212
    It's slightly bigger, will get down to 20hz in small to medium sized rooms, sealed, PEQ, balanced, unbalanced, no remote, several finishes. Unfortunately only obtainable through SVS...$700-850 depending on finish. SQ should be similar to the SPL 1200. If you need a small footprint sub this is a great alternative.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • harold280z
    Bedroom sounds!
    Sony Bravia 40XBR1
    Polk RTi 8's front
    Polk T20e rear
    Polk RM 202 center
    Polk PSW 10 sub
    Thanks for all the help, I've hear the Slp's 800 & 1000 but I got the martin logan dynamo, it sounded very tight. I'll let you know how it works!
    Bedroom Stuff 5.1
    Harmont Remote 880
    Polk RTi8's Front
    Polk T20E's Rear
    Polk RM202 Center
    Basement Stuff 7.1
    Sony STR ES5000
    Sony DVD NC55ES
    Pioneer Elite 910HD
    Harmony Remote 688
  • harold280z
    Bedroom Stuff 5.1
    Harmont Remote 880
    Polk RTi8's Front
    Polk T20E's Rear
    Polk RM202 Center
    Basement Stuff 7.1
    Sony STR ES5000
    Sony DVD NC55ES
    Pioneer Elite 910HD
    Harmony Remote 688
  • SLOCOOKN
    SLOCOOKN Posts: 704
    Congrats on the sub purchase. I hear They make great subs. Keep intouch.
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
