Help with setup please.
EFW
EFW Posts: 28
edited December 2006 in Speakers
I have an Onkyo TX-SR703 AVR, (2) Monitor 70's Front, (2) Monitor 40's Rear, (1) CS2 Center, and (1) PSW12. I curently have the front, rear, and center speakers run from the AVR with 10ga. Monster Cable, and the PSW hooked up solo with a Moster 1000 Subwoofer Cable. Is this the best way? Or the wrong way? How many right ways are there? Any help would be greatly appreciated, I have not been in the high end surround sound world before and could use some advice. Thanks...................EFW:confused:
AVR...........Onkyo TX-SR703
TV.............Mitsubishi WD-62627:D
HD DVD.......Toshiba HD-XA2:cool:
Power.........Monster HTS 1600
Mains.........Monitor 70's
Center........CS2
Rears..........Monitor 40's
Sub............PSW12
Cables........Signal Cable
Post edited by EFW on
  • cfrizz
    cfrizz Posts: 13,415
    Welcome to CP EFW!
    You have a fine system there & it's hooked up just right! Now sit back & enjoy.
  • EFW
    EFW Posts: 28
    Do I hook the Sub (PSW12) up through the LFE in (ufiltered), or with the spliter on line in (filtered)?
    Center........CS2
  • ivansfo
    ivansfo Posts: 145
    EFW,
    Connect your SW output (pre-amp out) on the receiver to the LFE IN (Unfiltered) port on the sub.
    I think the Line In (L & R) are for receivers without subwoofer pre-amp out.
  • Frank Z
    Frank Z Posts: 5,860
    Welcome aboard!
    I'd like to add the following info for you.
    The Polk Audio Hometheater Handbook. is a great place to start.
    Get yourself a Radio Shack Sound Pressure Level (SPL) Meter and calibrate your system the right way.
    http://www.audiophilia.com/hardware/spl.htm
  • cfrizz
    I agree with Frank. However, do not use their method of connection for the subwoofer. They make it unnecessarily complicated! Just Use the LFE in.
    tonyb Posts: 33,014
    I agree with both Frank and Cathy....also look at your crossover selection in your AVR.Start out somewhere in the 70-80 hz range and you should do well.You might have to play with placement of your sub to keep it from not sounding boomy.Nice set up..enjoy!
