speaker compatible?
clefty
clefty Posts: 2
I have a sony home theatre system (84W/ch 3 ohms) 4 speakers, and (160W 1.5 ohms) subwoofer. Will it be OK to substitute a POLK AUDIO (MONITOR SERIES 2) rated at 8 ohms for the front speakers and not damage anything?
Thanks.
Post edited by clefty on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited December 2006
    You won't damage anything hooking up 8 ohm speakers but will require calibrating the level to compensate for the brand change, ohm load difference, and sensitivity of using different speakers.
  • clefty
    clefty Posts: 2
    Thanks Dennis. Your answer is appreciated.
