Replacing a Bose System (ugh)
dgt2n
My 2002 Pathfinder came with a facorty installed Bose system. The CD player now completely refuses to play, and I'm finally done dealing with it. Crutchfield has really nice adapter kits, so I'm leaning towards buying from them.
I'm looking to spend ~300 on the head unit, and upgrading speakers somewhere down the line. I've read a few reviews, and right now am leaning towards the Alpine 9856 or 9857, but really have little/no experience upgrading car audio equipment. Does anyone have any strong feelings for or against?
Post edited by dgt2n on
Alpine makes good HU and great amps, so you wouldn't be disappointed with that choice, I'm sure. However, I'd personally look at Pioneer's Premier HU's, Kenwood's eXcelon offerings, and Eclipse's HU's, as well. Probably the best thing to do is to sit down and decide exactly what it is you want out of your system, and then figure out what features you need/want in an HU to acheive that. Then figure out via the web which HU's meet those needs/wants, and then you can make the final decision in store, playing with the various HU's.
I'm not 100% positive, but when you're dealing with an aftermarket system such as the Bose system, I'm pretty sure once you replace the speakers or the HU, you have to go ahead and replace the other. Meaning, I don't think an aftermarket HU is going to be compatible with the Bose system.
I would probably rip out ALL the Bose stuff and get an aftermarket HU and some cheap speakers up front to run off just the HU until you're ready to move on, or do some more research and go all out the first time with the HU, front speakers (components?), and an amp.
You looking to do components up front? You want rear speakers? You looking to get a sub in there sometime, too?
Wow, Honda's are coming with Bose systems? That's a shocker...never would've guessed...
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
FWIW - I had a Nissan Maxima with a Bose and was able to use a kit to keep the speakers with an upgraded HU.
Well, there you go...you can just replace the HU. I don't imagine the adapter kit would cost too much, so that might be a good first step.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
It's a Nissan, not a Honda, and it was a factory installed Bose system, not aftermarket (I know enough to not go out of my way for Bose).
I'm fairly certain I can just replace the HU, and I can get an adapter harness from Crutchfield. I'm pretty pleased with the stock speakers (for now).
My main want is a nice ipod hookup/interface. Along with sound, obiously.
Thanks for the suggestions. -
Who thought it was a Honda? I once owned a Pathfinder. Thirty some cars in the last 30 years, but never a Honda. Decent enough cars, but I have always selected something else, but typically a "foreign" car.
audiobliss wrote:Wow, Honda's are coming with Bose systems? That's a shocker...never would've guessed...
I was replying to this...
thanks again for the help guys. -
My bad...of course the Pathfinder is a Nissan.
And I didn't mean to say the Bose system was aftermarket, by any means.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
After a little more research, i decided to go with the Pioneer 6800. Hopefully this installation goes smoothly. I'm pretty experienced with home audio, but cars and I don't get along very well...
My good friend has that same HU, he really likes it.
As far the the Bose system, at low levels it sounds ok, anything more and the system is easily overwhelmed. At least this was the case in my 2002 Maxima. Mine came with a subwoofer too. Upgrading speakers down the road as you have mentioned will make a nice difference.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
