Amp Troubleshooting
Marcinko7
Marcinko7 Posts: 121
edited December 2006 in Electronics
I purchased a new Outlaw 7500 5 channel amp and after hooking it up cannot get sound out of any of the channels except for a hum out of the right main. I'm connecting it to a Denon 3806 AVR. I have an older 2 channel amp that works fine off the Denon pre-outs. When I switch the left and right front RCA input cables at the amp, the hum still comes off the right channel. When I unplug the right RCA cable the hum stops and no sound at all. Outlaw has sent me a replacement amp and the exact same symptoms appear. I don't think its the amp for this reason. Outlaw tells me they never have problems with the 7500. I'm using banana plugs on the speaker wires and they are hooked up correctly. The RCA cables are new monster audio cables and I have tried an older set with the same results. The switch on the back of the Outlaw is set to unbalanced. There is no switch on the back of the Denon. I'm about to give up this just makes no sense. Any ideas?:(
Denon 3806 Receiver
Denon 3910 DVD
Oppo BDP-83 Blu-Ray
Outlaw 7500 300w x 5 @4 Ohms Amp
58" Panasonic 800U 1080P Plasma TV
SVS PB-12 Plus Sub
Lsi25 Fronts-Cherry
LsiC Center
LsiFX Surrounds
SMS-1 Velo Sub EQ
PBJ Interconnects
Blue Jeans Cables
Everything was going just fine till my buddy poked the cop in the chest and said "did Andy give you your bullet today Barney?"
Post edited by Marcinko7 on
  • danger boy
    danger boy Posts: 15,722
    that is very odd indeed. Seems like the Denon and the Outlaw are not compatible.. which doesn't make any sense. what type of cables are you using between the Denon and the amp? RCA or the three pronged ones (XLR)?
    i could understand if you were getting a hum.. on all channels.. but some of them you aren't getting any sound OR hum from.
    Does the other old amp.. is it two channel or 5 channel? And you get sound from all channels out of it?
    PolkFest 2012, who's going>?
  • Marcinko7
    They are new RCA cables, the Denon does not have the balanced outputs. The older 2 channel amp works perfectly.
    Denon 3806 Receiver
    Denon 3910 DVD
    Oppo BDP-83 Blu-Ray
    SVS PB-12 Plus Sub
    Lsi25 Fronts-Cherry
    LsiC Center
    LsiFX Surrounds
    SMS-1 Velo Sub EQ
    PBJ Interconnects
    Blue Jeans Cables
  • PolkThug
    PolkThug Posts: 7,532
    Run an analog output directly from your DVD player into the outlaw and see if it works.
