15" titanic mk111
ronnie
ronnie Posts: 150
i know svs and hsu is the love around here, but for 690.00 bucks and maybe an hour of my time i can get a 15in. sub with a 1000 watt amp, hitting around 20hz, and the enjoyment of putting it together.....sounds beautiful to me!!!!! is it worth it????? really, how can you go wrong, right?? does anybody have one and do you think it is worth it....i was going to get a psw505, but for a little more i can get this beast...any opinions are much appreciated...thanks
Yamaha RX-V2600
Adcom GFA555 x 2 :D
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects
Post edited by ronnie on
  • tryrrthg
    tryrrthg Posts: 1,896
    edited December 2006
    Unless you've got a smallish room you won't get much output at 20hz. The kit is a sealed design which means the response starts rolling off in the 30-40hz range. In a larger room you'll need some EQ like the Behringer Feedback Destroyer to boost the low end (or another titanic)
    My DIY 15" sub does pretty well in my 14x23 room but I need some EQ to get the low end up. But I don't listen at very high volumes when watching a movie.
    Personally, I'd either build a sub myself (no kit) or go with one of the internet sub companies.
  • phoneisbusy
    phoneisbusy Posts: 867
    It'll take more then an hour of your time especially if you want to do it right. Don't forget to factor in additional tools/supplies or time required to haul the project out to your friend's workshops (beer). ;)
    You may consider the time spent as part of the enjoyment/satisfaction quotient but if you really want it now, it may end up being more then you expected. I'd build my own but then I've been planning for a year or more now (i.e. child care). :D
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Buy it, build it, be different.
  • Early B.
    Early B. Posts: 7,900
    Yeah, it should work fine and it'll probably be far superior to your current AR sub and the psw505. The Titanic subs are highly regarded. The only downside is resell value.
    BTW -- you can build it a lot cheaper if you buy the woofer and build the box yourself. Consider getting a separate amp to power it.
    "God grooves with tubes."
  • shack
    shack Posts: 11,154
    I built (ok...put together) the 10" Titanic and it was well worth the time and effort. Mine is a great little sub.
  • Deadof_knight
    Deadof_knight Posts: 980
    BUILD IT ! its great fun
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
