SurroundBar Mounting
kferdman
I am in the process of Mounting my LCD HDTV and the SurroundBar on the wall. For Ideal viewing my LCD HDTV will be mounted so the center of the screen is 50" from the floor. I cannot mount the SurrondBar below the TV because there is furniture closer than 3 feet. So I must mount it above the TV. My question is this:
If I mount the surroundBar on the wall, 75" high, will that effect the performance and my listening pleasure?
Post edited by kferdman on
No. It should fill nicely. IIRC you can angle it slightly.
Lemme know what you think...
