Probably another dumb question...
shawn474
shawn474 Posts: 3,052
edited December 2006 in Electronics
What is the advantage in having an SACD player and / or a DVD audio player? s it better sound only? Seperate CD's and DVD's that only support these? I know some players do both. Is SACD relegated to strictly CD sound formatting and DVD Audio is a seperate DVD sound format? Thanks again for the replies.
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    SACD and DVD-A are both hi resolution audio formats. Most discs have stereo and multi channel tracks to choose from too.
    It is your choice what type of player to buy. They make SACD only players, SACD/CD players, DVD/DVD-A/CD players or universals that play them all.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    are they still making dvd-a only players?
    F1nut Posts: 50,812
    I believe Meridian had one DVD-A/CD only player. I can't think of any others, so you'd have to get a universal type for DVD-A. However, there are plenty of SACD/CD only players on the market.
  • dudeinaroom
    just wondering. I know either technics, or panasonic (one in the same anyways) made one when the format first came out. I'll stick with my sacd....for a while.
