Room layout question for LSiFX surrounds
I have a 60" Sony SXRD and a 5-channel LSi system (LSi15/LSiC/LSiFX). I have two choices, neither of which is optimal, but I could use some input.
1) Sit about 7 feet from the screen with one surround speaker above and to my left and the other surround speaker the same distance to my right, but about 2 feet forward.
2) Sit about 9 feet from the screen with one surround speaker above and 2 feet behind, with the other above and 4 feet behind.
I'm leaning toward the second choice. I'm wondering what the effect will be of one speaker being further behind than the other. Any thoughts?
Thanks,
Brian
Thanks,
Brian
Post edited by bdz1 on
Number 2 is the better choice. Surrounds in front of the listener interfere with signals from the mains. Even sides on a 7 channel setup should be slightly behind the seating area if possible.
Make sure you calibrate speaker volumes to overcome the distance difference.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Yep- get them behind you. The distance settings in your pre/pro/AVR should help iron out the differences.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I vote #2 as well.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
I sit 6-7 feet from my 42" hdtv, for a 60" I would go with option #2.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
