bd500
Systems
Systems Posts: 14,873
edited July 2002 in Car Audio & Electronics
I have a fosgate bd 500 power ampliefier i really want a new momo 12 inch woofer but then i can only run the amp at 4ohms and get at most 400 watts rms out of it. Will this be enough or do u suggest to get a bigger amp?
Testing
Testing
Testing
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited July 2002
    this amp is rated at 250 rms for that speaker
    umm...since the amps are highly under rated i would say u might be able to squeeze 375 watts out of it but if i were you i would go with a slightly bigger amp
    like a 750 or something like that
    my 2 cents
    -Cody(no relation)
