Would This Setup Pound?
gipanizer
gipanizer Posts: 3
edited February 2007 in Car Subwoofer Talk
Post edited by gipanizer on
  • gipanizer
    gipanizer Posts: 3
    edited December 2006
    heres the tech specs
    Manufacturer Power Acoustik Electronics
    Output Power 800W (RMS) / 1800W (PMPO) - Woofer
    Additional Information 2" BASV voice coilTuning: 40 HzPort Size: 4"(Diameter) x 8.75"(Length)Number of ports:1Die cast aluminumRoyal Blue Finish With Diamond CutChrome finish back plateLarge foam rubber surround1-piece rubber gasketBlack poly-cotton spiderWoven tinsel lead through spiderChrome push terminals
    Manufacturer Part Number FUBAR-12W
    Driver Type Woofer
    Material Paper
    Impedance 4 Ohm Woofer
    Weight 200 oz - Magnet
    Country of Origin China
    Product Model FUBAR-12W
    Product Name FUBAR-12W Sub-woofer
    Sound Pressure Level 91 dB
    Product Type Woofer(s)
    and heres for the amp
    * Heavy Duty Construction
    * MOSFET Power Supply
    * Thermal Protection
    * Circuitry Overload Protection
    * Full Selectable Crossover Low/Flat
    * Chrome Plated RCA Connectors
    * Instruction manual
    * 700 Watts RMS POWER INTO 4 OHMS
    * 1100 Watts RMS POWER INTO 2 OHMS
    * 1600 Watts RMS POWER INTO 1.3 OHMS
    * 2000 Watts RMS POWER INTO .5 OHMS
    * THD@ 1WATT/4 OHM: 0.2%
    * S/N Ratio:98dB
    * Jedi effect blue tracking lights
    * Frequency Response: 10-30khz(+/-3db
    * Damping Factor @ 20hz/4Ohms:400
    * Low Pass Filter: 50hz-500 hz
    * Bass Boost:+18db@40hz
    * Phase Control:0 to 180
    * Input Sensitivity:200mv to 8v
    * Input Impedance: 10k Ohm
    * Line Output Impedance:100 Ohm
    * Fuse Rating: 25A X 2
    * Variable low pass:50hz-500hz
    * Measurments 2"X 10"X 14 "
  • gipanizer
    gipanizer Posts: 3
    heres another setup im considering
    http://www.buy.com/prod/Power_Acoustik_****_12_12_2400_Watt_Woofers_with_Ribbed_Cone_Insert/q/loc/111/90105940.html
    http://www.amazon.com/Sony-Mono-1-Channel-Amplifier-XM-1600GSD/dp/B000069UZ4/sr=8-1/qid=1165048128/ref=sr_1_1/103-9955346-7019850?ie=UTF8&s=electronics
    specs on amp XPlod 1600-GSD. This amp gives you 1200 Watt 1-Channel Class D Pulse Width Modulation, 1200 Watts Max Power (into 2 ohms)/300 Watts x 1 into 4 Ohms
    specs on sub
    Output Power 1200W (RMS) / 2400W (PMPO) - Woofer
    Additional Information 3" BASV/Kapton Hybrid 18 AWG Voice CoilTuning: 40 HzPort size: 3"(Diameter) x 6.75" (Length)Number of ports: 2Non-pressed paper cone with aluminum rib insertDie cast aluminumMetal-flake Royal Blue Finish With Diamond CutChrome Finish Front & Back PlateLarge foam rubber surround1-piece Rubber GasketDual Conex SpiderWoven Tinsel Lead Through SpiderChrome Screw Terminals
    Manufacturer Part Number ****-12
    Driver Type Woofer
    Material Paper
    Impedance 2 Ohm Woofer
    Product Series ****
    Weight 270 oz - Magnet
    Product Model ****-12
    Product Name ****-12 Sub-woofer
    Sound Pressure Level 90 dB
    duz this look like a nice setup? according to the amp it will pump 1200 watts at 2 ohms. and these subs are 1200 watt rms and 2 ohms. so would this package be better then the first?
  • jegs
    jegs Posts: 15
    Hmmm. The FUBAR series woofers. With a name like that I think you are asking for problems.
  • mirra540ryder
    mirra540ryder Posts: 136
    i never seen anybody have thems subs. maybe theres a reason behind that =\ ive never seen anybody buy that brand of sub
