NAD T743 vs NAD 7600 vs Onkyo tx-sr703
rrage
rrage Posts: 10
edited November 2006 in Speakers
which would be better quality to go along with 2 fronts of lc65i, 1 center lc265i and 2 lc60i surrounds or do i need more power. I don't need to get blown out of my 17'x18' room but want enough power. I'll be using a 42" philips plasma 42pf7320a. I was leaning toward using psw505 sub as i can get it for about 350.00. My amp will be my last purchase, I appreciate any help as i continue to build my HT, let me know if i'm on track or not, thanks.
Post edited by rrage on
  • univera
    univera Posts: 848
    I own the Nad 773 and have owned the 7600. Both sound fantastic. The 7600 doesn't have a built in DTS decoder, so it that's important, I'd rule that out. It also doesn't have a ton of digital connections. I believe it's 80 or 90 wpc. Nad AVRs are very musical and do a great job at two channel and HT. I haven't heard the Onkyo, but IMO, Nad is a better product. The 743 is the same as my 773 only with less power. I highly recommend it.
    Should you go with a 7600, you should be able to find one under $500.00 I sold mine for $450.00 and maybe charged shipping. Can't remember.
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
  • rrage
    rrage Posts: 10
    Univera thanks, i was kinda leaning to the t743.
