AQ DBS voltage question
candyliquor35m
candyliquor35m Posts: 2,267
edited November 2006 in 2 Channel Audio
I know the higher the voltage the better they are supposed to sound but if I'm happy with my non-dbs AQ's including a couple pair of king cobras, should I even be worried about the voltage? The reason I'm asking is it seems I can get a pair of AQ DBS 12v xlr's for under $200 but I can't find a pair of king cobra xlr's for under $200. I want a pair of xlr's to see what balanced sounds like on a 75 watt tube amp.
And if the battery ever dies, aren't I still left with a quality set of solid core ic's?
Thanks.
Post edited by candyliquor35m on
  • steveinaz
    steveinaz Posts: 19,546
    I think you just answered your own question. Never upgrade just for the sake of upgrading, if your happy with what you've got---leave it be.
