Basement Speaker Wiring
pbrown22
pbrown22 Posts: 1
I know this has probably been posted before, but I was not getting good answers to my searches.
I am finishing my basement and want to run the speaker wires in the walls and/or ceiling. I just don't understand the best way to do this. A friend told me to use conduit, but I am just not sure how it works. I know there are restrictions about following the electrical wires, but any suggestions are welcome.
Any good sites to demo this? Any good suggestions period?
Thanks in advance.
Post edited by pbrown22 on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited November 2006
    Conduit is great if you ever want to "upgrade" the in-wall wire. The conduit would be run through the ceiling joists, or walls. If/when you needed to run new wire, you can just attach the new wire to the end of the old one and pull(although it doesn't always work).
    If you don't think you will be in the house for a long period of time, or if you have high quality(good shielding), wire to begin with, then you wouldn't need the conduit.
    Another rule of thumb would be to keep speaker wire at least 6" away from the electrical lines if you have to run them parallel. If they are run perpendicular to each other, there won't be a problem.
    I would suggest running high quality wire(good in-wall rated) to begin with, so you won't have the need to upgrade later.
    Tschüss
    Zach
  • Lowell_M
    Lowell_M Posts: 1,660
    I used 12-ga In-wall Belkin wire in my basement project, but can't remember who I bought it through. Anyway, it has a real nice outer covering that allows for pulling through studs and such without damaging the wire. Looks like nice wire, although i don't have much experience to compare it to.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Sansui
    Sansui Posts: 372
    It can be real hard pulling wire through three or more 90* turns even if someone is push feeding the wire on one end regardless of the size of conduit used. Just a thought...
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
