First Time
Hi there so i want to spend a little $$$.I have a sony E.S. 6.1 receiver I think its 150 w. per channel. I know i want the RTi12s and the CSi5 for the center. Circit city trying to talk me into the CS2. I need to know what to get for the back 3 speakers. Monitor 40 for the sides or better? Would a CSi3 be wasted on the rear center. I dont want to wast the receiver and i dont want to buy rear speaker that i'me only pushing 15% of what they can do.Valodine dps 12 will be the sub, is this better then the polk PSW505?
Want to do it right the first time. Thanks for all your help:D
RTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
PHILLIPS 42" PLAS. 1080i
Monster 5100 SS
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
Monster 5100 SS
Post edited by toddco on
toddco wrote:Hi there so i want to spend a little $$$.I have a sony E.S. 6.1 receiver I think its 150 w. per channel. I know i want the RTi12s and the CSi5 for the center. Circit city trying to talk me into the CS2. I need to know what to get for the back 3 speakers. Monitor 40 for the sides or better? Would a CSi3 be wasted on the rear center. I dont want to wast the receiver and i dont want to buy rear speaker that i'me only pushing 15% of what they can do.Valodine dps 12 will be the sub, is this better then the polk PSW505?
Hi toddco,
Welcome to the Club Polk. You are in good hands here. If you want to get Rti12s you are going to need an external amp (200wpc and up). Your Sony SE receiver is a fine machine, but you need a lot of power to drive 12s and to get the most out of them. When I say power I am referring to amps with big transformers to make 12s happy.
I dont know the size of your room, but I think you would like Rti8s or 10s with sub for HT. For your centre the Csi5s is awesome. Also, surrounds I would stay with Rtis series to match you system. As for the rear center Csi3 would be great. I have no experience with Volodine, but most members on this forum go for SVS, HSU, Volodine .
Cheers
Gator
Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
Hi tod,
Gator is absolutely right about the 12's, go for 10's and get an HSU sub instead of the velodyne. It hits alot harder, lower and is about the same price as the velo you want. Google HSU and look at what they have. Great sub's.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
Hey tod,
As the others have said, you will want to drive those 12s more, I have a 7100 es receiver and am using two outlaw M2200 monoblocks on each speaker along with receiver power to biamp the 12s. As for rear since you want to go RTI series up front go with a CSi5 center, FXi5/FXi3 rears and SVS sub, you will love ya self for that purchase.Shoot the jumper.....................BALLIN.............!!!!!
Knok yourself Out!
http://www.vanns.com/shop/servlet/item/features/549499051
Get this and you will not be sorry....Audio system lost to water damage...
I have been told theFXi5 and 3 were for 5.1 and to use in a 6.1-7.1 is not the way to go. The fill you get is not right for 6.1 and bigger.
RTi12's:D
CSi5
FXi5
CSi3
PB12+2 :cool:
Sony STR-DA2ES
Outlaw M200 x3
SMS 1
Signal Ultra
Sig.2 Inters.
PS 3
Xbox360 Elite
Monster 5100 SS -
Hi Toddco, welcome to CP. The FXi 3's & 5's are for surround sound duty in any configuration that you want to put them in. As for the rest, the others have given you good info & ideas.
Could you please tell us the exact model of Sony receiver you have, that way we can see if you have preamp outputs in which to add separate amplification to later on.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
