Panasonic TH-42PX600U........
Systems
Systems Posts: 14,873
edited November 2006 in Electronics
Hello
Been thinking about finally upgrading our old Sony and was wondering if any of you had the Panasonic TH-42PX600U?
I wound up getting a PSX 3 which I'll replace our old DVD player with and that should look great on it, I would hope:)
I am currently using a Directivo via an s-video hookup and don't plan on moving to high def satellite as of yet. I read quite a few user reviews on c-net and it sounds like a Plasma will give a fair SD picture.
Anyway just wanted all you experts opinion on this one....
One other thing the specs on Crutchfield says it will do 1080P but the specs at Panasonic doesn't list that??
http://www.crutchfield.com/S-NsQ0LV3iNfR/cgi-bin/ProdView.asp?g=146350&tab=detailed_info&i=13342PX600#Tab
http://www2.panasonic.com/webapp/wcs/stores/servlet/vModelDetail?storeId=15001&catalogId=13401&itemId=97562&catGroupId=24973&modelNo=TH-42PX600U&surfModel=TH-42PX600U&cacheProgram=11002&cachePartner=7000000000000005702
Testing
Testing
Testing
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I believe Crutchfield is wrong, because it says it will do 720p / 1080i as 1399x768 format. The problem is that 1399x768 is used for the 50" model not the 42" HD models. So based on this I say not 1080p, since the panny site doesn't state this also.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
