Dolby 5.1
bigrodge
I have a new system and I'm not that impressed with the surround sound. Is Dolby digital 5.1 a subtle experience or should I really be immersed in sound?
I have a Pioneer VSX-816 Receiver, Samsung HD 960 DVD Player. 4 Polk M50 monitors, CS2 centre channel and a PSW10 sub. I seem to get better sound when I set the receiver to the expanded or 7.1 settings. I seem to be adjusting settings constantly....Am I being to critical?
Post edited by bigrodge on
What is your source, where is the signal coming from? How do you have this hooked up, RCA L/R, coax digital, or optical digital?
Give us more details we like details.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
you are probably not getting real dolby digital but something along the lines of 5ch stereo. does your receiver say dolby digital on the front of the display? are you using a digital connection(coax/optical) between your dvd player and receiver? do you have dolby digital and dts enabled in your dvd menu (i know its stupid but it happened to me and several others upon getting a new dvd player).
if you are actaully getting dolby digital 5.1 all the dialogue pretty much will come fromt he center and you will be able to pinpoint locations of event when they happen off screen for example when a someone knocks at the door offscreen you know where the door is even though you cant hear it. try using the matrix reloaded, it has a wonderful soundtrack and uses all of the channels extensively.
hope this helps -
disneyjoe7 wrote:What is your source, where is the signal coming from? How do you have this hooked up, RCA L/R, coax digital, or optical digital?
I have DVD hooked up to a Panasonic Plasma with a HDMI cable, the audio is connected with component audio cables to the amp. The settings on the DVD player are....
DIGITAL OUT - bitstream
DTS - off
DYNAMIC COMPRESSION - off
PCM SAMPLING - off -
The receiver does say DOLBY PL...How about 'SAVING PRIVATE RYAN' ...Is that a movie that should test the system?
Are you using the Digital output from the TV? If so this is your problem, run it from your DVD player. The Panny TV is not giving you DD5.1 from the HDMI cable, I know I have the same TV.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I think this setting is wrong also, but I understand why due to the TV thing. Anything else you'll get nothing.bigrodge wrote:The settings on the DVD player are....
DTS - off
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:Are you using the Digital output from the TV? If so this is your problem, run it from your DVD player. The Panny TV is not giving you DD5.1 from the HDMI cable, I know I have the same TV.
Before you take any advice from the peanut gallery........;)
Have you calibrated your system using an SPL Meter?
Linky -
What a dummy I've been !!!! I had it only hooked up to analog inputs, I thought the receiver would do the rest...just used the digital optical connection and now I'm happy...what a difference !
Thanks for all your help and please feel free to ridicule me, that's what happens when you think you know it all......next time I'll read the manual a little more carefully.
Hard to believe I'm an engineer ..heaven help us all. -
Ok, happy you got it fixed. The digital optical from the TV doesn't give you DD5.1 output from the HDMI input, it gives you DD5.1 from antenna input only for HDTV local. I know this because I had the same problem.
Frank Z, what you're saying the peanut gallery, you should give me a little more credit.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:Frank Z, what you're saying the peanut gallery, you should give me a little more credit.
You were getting a Dolby Pro Logic (DPL) downmix. You can get DD 5.1 out of the analog outputs if you have settings in your player to decode the signal then pass it along through the multi-channel analog outputs. Using the optical or coaxial digital connections uses the receivers decoders.
Glad you found your problem.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
turn that DTS setting on if your receiver can decode itShoot the jumper.....................BALLIN.............!!!!!
Frank Z wrote:You missed the winky.
Sorry I missed it, I didn't know what winky was about. :eek:
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
bigrodge wrote:...
wallstreet wrote:You don't build bridges, buildings, or airplanes do ya? If so, which state?
