Paint Ideas...
VR3
VR3 Posts: 28,817
edited November 2006 in The Clubhouse
Yep... so Im contemplating stuff for the next week (if not immediate future)
Of course, stick to the basics...
WHite trim, white ceiling - yada yada yada...
Im thinking about a yellowish, brown - kind of a dark tan color... very warm for the side walls...
And a darker grey... similar to Toyota's Flint Mica color or w/e - and yes, I just thought about painting my walls a color of a car...
But seriously, a darker grey for the front and back walls with a warm tan looking color... I would show pics of samples - but every paint thingy Ive seen so far is jasc and java and I dont feel like taking screenshots...
But anyways... furniture will be black, oak, and walnut - any ideas or suggestions?
Thanks...
Post edited by VR3 on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    even if you did post samples, the colors would be off as every monitor, video card, and users have different settings. Mine is pretty close to life like. I used a couple of programs to calibrate it, one was an adobe program, and I don't remember the other.
    VR3 Posts: 28,817
    Thanks for that info...
    And while Im glad you presented it...
    Any opinions on the idea there? ;)
    VR3 Posts: 28,817
    Ok....
    So...
    I got some samples from HD - just general colors, not more so the paint...
    But I think I want something like this - not 100% sure, I kind of like... the top row, left and middle samples - like I said though, not 100% how these colors go together or w/e...
    Just getting opinions and suggestions...
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    If you like these have you tried to go behr.com for color ideas?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • MillerLiteScott
    MillerLiteScott Posts: 2,561
    Ok....
    So...
    Those color tones are very similar to what we painted our HT room. It should sound better with the greenish color as the accent color.:D
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • disneyjoe7
    Green funny that's what Behr said to use with that Adobe Straw color.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • wallstreet
    wallstreet Posts: 1,405
    top row middle gets my vote out of the selections. I'd go a tad greener personally. It's a relaxing color.
  • TheReaper
    TheReaper Posts: 636
    That was fun :)
    user: emailaddress@example.net
    password: password
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • disneyjoe7
    It gives you nice visual :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    VR3 Posts: 28,817
    Whats the difference between eggshell and satin?
    Whats the price of Behr eggshell and satin? and the 75 primer?
    Thanks...
  • disneyjoe7
    I think about a dollar or so, for eggshell or satin.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • scottnbnj
    scottnbnj Posts: 709
    if the trim paint doesn't lay down well, use an additive like floetrol. if you're going to use behr, i'd just buy the floetrol rather than make another trip later.
    satin sheen reflects more light than eggshell. eggshell won't highlight defects as easily, but also won't clean as easily.
    for the time spent painting and prepping the room and how long the paint will last, i don't think the few bucks should even be a part of the consideration. this paint is going to stare you in the face every day for a long time, things like whether you need to hide defects, how well or if you're going to fix and prime them, if you want more light reflected back into the room, how well it cleans and stuff like that should be much more important.
    VR3 Posts: 28,817
    Im not asking for price difference,
    Just price...
    How much to expect, etc...
    Thanks though...
    I think Ill probally go for Satin though... hmm
    Thanks for comments/suggestions!
