Using different gauge wire
Home Theatre
When I was rewiring I ran out of wire. So my right surround and center channel have different wire. Is this going to effect sound at all? Kind of a stupid question I know.
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
It's something I wouldn't like, feeling all wires sound different.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I would say get new wires, I wouldn't be able to live too long w/out the same wires in the front, same should go for a center channel if you have one and make all 3 wires the same length too!
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
Home Theatre wrote:When I was rewiring I ran out of wire. So my right surround and center channel have different wire. Is this going to effect sound at all? Kind of a stupid question I know.
I know many will disagree w/ me, but as far as I can tell, as long as you have wire of sufficent gauge for the length, and good connectors properly fastened on the ends, you should be just fine. If you change it & hear a difference, I would be intersted to hear all the details.
Cheers, JimA day without music is like a day without food. -
He will / You will.
Cheers, Steve
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Are the guages the same on both types of wire?
BTW, if I had to extend any wire runs and had to use a different guage wire I would make sure the larger guage wire was leaving from the amp and the smaller guage wire was the extented to and hooked up to the speaker(s).Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
