Upconverting component to HDMI
kmartin971
I just hooked up my XBxox 360 HD DVD player and it will not upconvert standard DVDs over component. Any ideas on how to fix the problem? Any suggestions for a good Upconverting DVD player that will upconvert over component cables? My 65 inch mit supports 1080i but does not have hdmi inputs.
I found one product - will this work? (Link below)
TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Side Rear (2) = LSiFX
Rear (2) = LSiFX
JBL S120P II
Sony Upconverting DVD Player
XBox
XBox 360 (Wireless connection live and media center enabled)
PS3
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3
Post edited by kmartin971 on
TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
That does the reverse of what you want. It converts VGA or Component video to HDMI.
What you want is something that converts HDMI to Component Video. Good luck in finding it though (you might try China or somewheres else overseas).Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
This sucks - Otherwise the 65' rear pro HDTV mit has been amazing! The King Kong HD-DVD was amazing compared to 480p on my pioneer elite DVD player!TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
How about this one?
http://cgi.ebay.com/HDMI-to-VGA-RGB-HD-15-Component-Video-Format-Converter_W0QQitemZ320049893260QQihZ011QQcategoryZ294QQssPageNameZWDVWQQrdZ1QQcmdZViewItemTV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
Your tv wouldn't happen to have a VGA input would it? That would be an easy way around: HDMI -> DVI -> VGA.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
If you care to go down this route. For upconverting DVD players search for hacks. I think there might be a hack for one of the oppo players.
Personally, I use my computer to upconvert DVDs and outputover Component Video to my Toshiba rphdtv. I run software to strip the copy protection off, so then my video card lets me output it to Component.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
Sounds too time consuming! I need a simple solution!TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
It might work (if it doesn't don't blame me). It is from across the pond, but appears to have both the 50hz (europe) and 60hz (americas) timings in the specs:kmartin971 wrote:
http://www.lektropacks.co.uk/view_item.php?product=1000534&&category=5&PHPSESSID=c53eadc3c83953c540336608359e2f50
Also part of a discussion thread over there (europe) on converters, check out post #74:
http://www.avforums.com/forums/showthread.php?t=315181&page=5Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
Seller offers a 10 day return policy. I might give it a try.TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
Are you sure the 360 doesn't upconvert? There was an update not too long ago, and I could have sworn it now allows upconverting and not just 480p output. I haven't tried it though, so I can't confirm or deny.Brian Knauss
ex-Electrical Engineer for Polk -
OPPO makes a very good upscaling dvd player that upconverts via component video cables..
http://www.oppodigital.com/?partner=111
Or look around for a samsung hd-841 which is the dvd player that I have and it upconverts via component video easily...My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Thanks - I bought a hdmi to componet converter that will sit between my receiver and tv. Receiver has hdmi and tv does not Hope it will be delivered on sataurday and Hope it works!
http://cgi.ebay.com/HDMI-to-VGA-RGB-HD-15-Component-Video-Format-Converter_W0QQitemZ320049893260QQihZ011QQcategoryZ 294QQssPageNameZWDVWQQrdZ1QQcmdZViewItemTV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3
