Sony Xplod 2400w sub - What is the best amp?
pregnantNproud
Ok my problem is ongoing and driving me crazy.
I have two 1,200w Sony Xplod subs, not exactly like these but VERY similar
http://http://www.sony.co.uk/view/ShowProduct.action?product=XS-L121P5&site=odw_en_GB&pageType=TechnicalSpecs&category=ICA+Subwoofers
And basically there is a class D monoblock amp someone recomended and i want to check with you guys if you think its suitable.
Its a 3000watt 2 channel: http://www.theloudest.co.uk/?sectionid=2&page=view_product&product_id=102
Each of my 1,200watt sub speakers are rated at 350RMS input and are 4ohm, what is the best set up with:
1 x 3,000 watts Max (@ 1 ohm)
1 x 1,000 watts RMS (@ 1 ohm)
Up to 1 x 700 watts RMS (@ 2 ohm)
Up to 1 x 450w watts RMS (@ 4 ohm)
1 x 600 watts RMS (@ 2 ohm THD+N < 2.5%)
1 x 320 watts RMS (@ 4 ohm THD+N < 1%)
Or is this amp rubbish and can you tell me what the best one for my subs would be?
Post edited by pregnantNproud on
Get new subs..
That dosnt say Sony...for starters...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
my sentiments exactly svs hey even check out paradigmChicomorales:)
