amping MMC6500's
2002tahoe
2002tahoe Posts: 79
edited December 2006 in Car Audio & Electronics
hey everybody, does anyone have advice on what type of an amp i should get to power a pair of MMC6500. Also does anyone have a good spot to hide an amp in a 2002 Tahoe?
2002 Chevrolet Tahoe Z71 4x4:
Kicker ZX250.2
Polk MMC6500
Pioneer TS-A1681R
Dual Kicker 05CVR124
X-File XR8002
Post edited by 2002tahoe on
  • spwuinmk67
    spwuinmk67 Posts: 797
    edited November 2006
    Why not go with a Polk amp? The C400.4 wouldn't be a bad match up for it. And it's not too big, so I'm sure it could be put under a seat somewhere.
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
  • 2002tahoe
    2002tahoe Posts: 79
    sweet, yeah i totally forgot about the under the seat placement, i was freakin out thinking i was gonna have to do a custom install but thanks
    Kicker ZX250.2
    Polk MMC6500
    Pioneer TS-A1681R
    X-File XR8002
  • 2002tahoe
    2002tahoe Posts: 79
    what do you think about this one http://www.sonicelectronix.com/item_6569.html# its quite a bit cheaper but rated around the same amount of power. The kicker ZX250.2?
    Kicker ZX250.2
    Polk MMC6500
    Pioneer TS-A1681R
    X-File XR8002
  • dtolb05
    dtolb05 Posts: 2
    i have an 05 chevy equinox with the 6500's run by the 400.4 and it fits perfectly under the seat...so you should have no problem placing it there
  • black magic
    black magic Posts: 669
    I'm looking to power a pair of MMC6500 with the C400.4 also. I'm thinking of going crazy so this is my plan. MMC6500 in front powered by the C300.2, and MMC6500 mounted in rear doors along with the MMC690 in rear panel, both of these will be powered by the C400.4.
    Its either that or just MMC6500 up front, MMC690's in the rear and use the C400.4 to power those (difference being i wont have MMC6500 mounted in rear door panels so i wont need the C300.2 either)
    i'm gonna need another battery or a cap or something, my tiny battery wont be able to handle it.
    Most Polk products are under rated, so don't be fooled. they make excellent products. I just ordered the MM2124, and an amp kit from sonicelectonix.com cuz they have great prices, i'd recommend using them or cardomain.com. cant wait for my c500.1 and mm21 to get here! :D
  • MacLeod
    MacLeod Posts: 14,358
    Sounds like a good plan! Youll have plenty of volume.
  • audiobliss
    audiobliss Posts: 12,518
    black magic - I don't know how you could swing this with your setup, but I'd much prefer running the MMC6500 off the C400.4. One big benefit of doing that is you'll gain a lot more flexibility with tuning options. Power is the other benefit. If you go with components in the front and rear doors, and the 6x9's in the rear deck, each component set in your rear doors will only be getting 75 watts; I don't like that. However, they are rear speakers, so you'll hopefully have them faded out at least a little bit.
    If it were my sytem, I think I would probably put a C400.4 with the front MMC6500's and then get a C300.2 to power a set of MMC6500 in the rear doors, completely foregoing the 6x9's.
    Whichever way you do it, though, will be sure to please.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • black magic
    i think i see what you mean, so overall its better to have to rear speakers louder?
    if i was only gonna have 1 pair of speakers in the rear, wouldnt the mmc690's be a better choice since they give off more mid-bass?
  • audiobliss
    I guess I didn't word that too clearly...kinda seems to be my trademark...
    Speaking strictly from a sound quality perspective, it's best to not even have rear speakers. Rear speakers will pull your soundstage back and mess with your imaging. However, some people like rear fill, and others want their passengers to have good sound, so rear speakers were created.
    As for why I chose the MMC6500's for the rear oppossed to the 6x9's, the MMC6500's would offer better sound quality for the rear passengers, and it wouldn't mess with the front soundstage/imaging too much, since they'd be firing backwards instead of forwards like the 6x9's in the rear deck would be.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • jroberts_101
    jroberts_101 Posts: 106
    use a c300.2 dude. i have that set up and it rips so clean!! if you don't like it youo can come to my house and kill me :) thats how much i am sure of the setup
    and only run the fronts. just disconnect the rears. trust me on this one
    Polk Momo MMC6500
    Polk Momo C300.2
    Polk Momo MM2124 (2)
    Polk Momo C500.1
    Pioneer DEH-P7600MP
  • audiobliss
    Wow. A C300.2 for $100. I have no use for it, and wouldn't wanna use it because I wanna biamp for more flexibility...but I'm so tempted to get one for that price.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    I just looked on Fry's website, and I can't find the C300.2 anywhere on there.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MacLeod
    WHAT!?!!?!?
    I want a 300.2 for my midbasses!!
    You cant find a 300.2 anywhere!
    I just looked on Outpost.com too and couldnt find it. Man I cant believe I missed that!
  • MacLeod
    Thanks bro, but dont worry about it.
    Ive got a couple other things I guess I should get squared away before I worry about new amps. Maybe by the time Im ready for some, theyll have those on sale again.
    I wonder why nobody carries the 300.2 anymore? You cant find them on Sounddomain or Crutchfield. I havent even seen any on Ebay lately.
