DVD Player on Analog?
Early B.
I'm still curious to hear the differences, if any, in the processing capabilities of my receiver vs. the Oppo DVD player for music. My Oppo is connected to the receiver via a digital cable. If I also connected a pair of RCA cables, I could toggle between analog and digital. So here are my questions --
1. If I use the analog option for CD playback, will the Oppo process the signal?
2. If I use the analog option for DVD playback, will the surround sound still function?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
1. Using the analog outs will use the Oppo's DAC.
However, if you use the receiver's surround processing or bass management, the receiver will do A-D conversion for digital processing, then a D-A conversion to generate the line level signal for amplification.
Many receivers do have a "pure" or "direct" 2 ch mode that bypasses any digital processing.
2. You would not get DD or DTS 5.1, as that requires the digital bitstream/connection to be decoded by the receiver. Make sure that the Oppo's digital output is set to "raw" or "bitstream" or "DD/DTS", and not to "PCM".
My answer to 2. assumes you're referring to the 2 ch analog outs. If the player has multi ch analog outs and internal DD/DTS decoders, you could still get 5.1 to your receiver using the multi ch inputs.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5.
