DB212-2 Polk Sub Box
Dan M
Dan M Posts: 1
This sub box is a 2 OHM load, are the drivers wired to load my amp to 2 ohms already or do I need to make the wire modification to load my amp ?
Help...would like to be sure before wiring it , thank you...
Dm...
Post edited by Dan M on
  • MikeC78
    MikeC78 Posts: 2,315
    edited November 2006
    If the sub box is specified as a 2ohm load then you'd need an amp capable of handling the 2ohm load.
    BTW, you will get more answers by posting down below in the "Car Audio" section.
    Mike
