turntables 101
danger boy
Can someone help me understand the main parts of a turntable? Specifically the tone arm components.
a few things I don't understand are.. and this may seem retarded, but i've never owned a turntable that had as many replaceable parts to upgrade on it.
1. stylus
2. head or headshell
3. anti skate
4. why do Grado's cost so much? :eek:
5. cartridge
1. stylus
3. anti skate
5. cartridge
PolkFest 2012, who's going>?
Post edited by danger boy on
go for technic 1200s, best turntable out for mixing and scratching. Would love to hear ya once you get good at it. LOLShoot the jumper.....................BALLIN.............!!!!!
You think Grados cost alot, check out some of the carts on AG.
You put record on table
You lower arm
You enjoy.
There you go DB all you need to really know!!!!!!!!!!
stylus=the sharp thing at the end of the arm, sort of needle like that actually touches the record it "reads" the record sending signals.
headshell=attaches to the tonearm, plugs in some type of way.
anti-skate= a force opposing the tendancy for the tone arm to skip (skate)across the record.
cost=to play must pay
catridge=attaches to the headshell and holds the stylus, receives signals from the stylus and puts a very small amount of voltage on them which it sends down the line.
that is down and very dirty, tons of stuff on Vinyl Asylum
RT1 -
Sorry - Duplicate post -"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
A couple of good reads from some articles I bookmarked. Some more technical than others.
http://www.goodsound.com/howto/2004_02_15.htm
http://www.goodsound.com/howto/2004_05_15.htm
http://www.kabusa.com/setup.htm
http://www.recordtech.com/ttsetup.htm
http://www.audiophilia.com/features/cartridge_setup.htm"Just because youre offended doesnt mean youre right." - Ricky Gervais
thanks... i'll get my read on.PolkFest 2012, who's going>?
Hey DB. . . I purchased Michael Fremer's 21st Century Vinyl. It tells you everything you want to know about a TT/tonearm/cartridge/stylus. He shows you how to mount three cartridges on three different tonearm/TT setups. I paid $29.95 for it but I've seen it for as low as $19.95. I've watched it twice and even an old analog junkie like me learned some new things. It also has a pdf that goes into great dertails on the subject.
http://www.amazon.com/21st-Century-Vinyl-Practical-Turntable/dp/B000HA4WU2
http://store.acousticsounds.com/browse_detail.cfm?Title_ID=29608
http://www.musicdirect.com/products/detail.asp?sku=VFREMERSETUPDVD
http://shopping.yahoo.com/p:21st%20Century%20Vinyl:%20Michael%20Fremer's%20Practical%20Guide%20to%20Turntable%20Setup:1809741893
http://www.cduniverse.com/productinfo.asp?pid=7272211
http://www.elusivedisc.com/searchprods.asp
http://search.reviews.ebay.com/21st-Century-Vinyl-Michael-Fremers-Practical-Guide-to-Turntable-Setup_UPC_094922597236_W0QQfvcsZ1177QQsoprZ55055029
Al, check em all out, some of them run daily specials. One or two of the above had the DVD for $19.00
Joe -
shack wrote:A couple of good reads from some articles I bookmarked. Some more technical than others.
Thanks for these sites Shack, I thought I had every site that had anything to do with vinyl. LOL
Joe -
I replaced the needle today on the Pioneer PL-530 turntable..and it sure made a big difference in sound quality. i highly suggest it.. needle ran about $20PolkFest 2012, who's going>?
danger boy wrote:I replaced the needle today on the Pioneer PL-530 turntable..and it sure made a big difference in sound quality. i highly suggest it.. needle ran about $20
Pictures man . . . pictures. -
hearingimpared wrote:Pictures man . . . pictures.
Ok. just for you.. don't tell anyone.
Pioneer PL-530
Years built 1977 - 79'
retailed for $250
used now $14
weight 23lbs (ugh)
*you can tell i need a record cleaner.. look at all the dust on that album :eek:PolkFest 2012, who's going>?
Very nice DB. What you need now on top of a record cleaning system is a record clamp. I have a couple of different types in my storage bin. When I get settled in my new home (the next few weeks) I'll dig them up and see which is the better fit for your TT. I send you one.
Question is your platter dished (slightly concave)? Solid or rubber mat? Is there a recess for the record label?
Joe -
Joe,
from what i have explored on the platter.. it's rubber mat. not concave. no recess for the record label.
tanks, AlPolkFest 2012, who's going>?
another slight problem developed after I installed a new needle. The left channel is quite a bit lower in volume then the right channel now. I am stumped as to why that is. With the old needle, the volume on both channels was equal, now they are not.
Any ideas guys?PolkFest 2012, who's going>?
DB, Check the leads going to the cartridge. Have you aligned the cartridge?
Very nice turntable!Carl -
danger boy wrote:another slight problem developed after I installed a new needle. The left channel is quite a bit lower in volume then the right channel now. I am stumped as to why that is. With the old needle, the volume on both channels was equal, now they are not.
Any ideas guys?
Al you need to check the azimuth. Tools needed: a mirror and a magnifying glass, as well as the ability to either turn the headshell from side to side or adjust the cartridge in the headshell.
1. place the mirror on the rubber mat.
2. gently place the stylus on the mirror.
3. with the magnifying glass, look at the stylus (head on) and its reflection. It should be exactly (or close as possible) to perpendicular to the mirror. The reflection of the stylus and the stylus itself should be in and exact straight line.
4. if in fact it is not, then loosen the headshell and rotate it until you get that straight line of the stylus & reflection.
See number six here.
Let me know how you make out.
PS: when I get settled, I'll get a record clamp out to you.
Joe -
hearingimpared wrote:Al you need to check the azimuth. Tools needed: a mirror and a magnifying glass, as well as the ability to either turn the headshell from side to side or adjust the cartridge in the headshell.
Joe
Who knew there was so much involved in setting up a turntable? I had no idea.
Joe and other's thanks for all the great info. I'd never be able to figure this analog stuff out without your help.
It'll be a while before I get the chance to set the turntable up.. have other "issues" going on at the moment.. ie: nasty killer amp problems. I'll get back to the TT set up in time though. it's fun stuff.PolkFest 2012, who's going>?
danger boy wrote:Who knew there was so much involved in setting up a turntable? I had no idea.
Dude the azimuth is just the tip of the iceburg. Why do you think Michael Fremer of Stereophile was able to publish a three hour DVD on turntable setup. I can tell you this though, once you get your TT/tonearm/cartridge setup properly, you will love that silky, smooooooooth, life like, sound coming off an analog source.
There is one thing. . . if you are an obsessive tweaker like me,:eek: you will never be done with the turntable setup. There will always be one more little eeeeek of perfection you can get out of the TT combo.:rolleyes: That part is definetely a curse.:eek:
Joe -
good turntable info in this thread for all the new Polkies now getting into vinyl like me. Have fun.
Now read up on preamps.
Definitly a good read. I'm learing alot.
i bought a turntable but no speaker i thought i could hook it up to me surround sound system but i'm not sure
. any one selling some good speaker?
some thing small, but not really big. -
Unless your receiver has a phono input it won't work. You can't hook your turntable directly to a speaker either. You'll need a phono pre-amp that you would connect the turntable to and then connect the phono pre-amp to an input on your receiver.
Thanks for the excellent read Joe.
Here is my first TT that I just purchased.
I think it needs alot of adjustments...lots of pops and cracks when I play an album...or maybe just crappy albums (they are very old). -
Interesting, what I take away from this excellent, very old, thread is that everyone that posted was very knowledgable, helpful, and STILL HERE posting TODAY.
Rock on.
Gear, stick around, do some research, get your learn on, and enjoy. -
Very cool indeed!
George Grand wrote: »Now read up on preamps.
This is worth reiterating. If your AVR has a phono input, you have to try an external Phone stage. For me it was a huge upgrade and well worth doing.
Oh yea, do not run the Phono stage into your AVR's phono input. I used CD input.Speakers: SDA-1C (most all the goodies)
