Need help finding a system in a box
We need some help. So my brother is looking for a decent system in a box, doesn't want to spend a lot of money on the system, just something good to put in the living room.
Any suggestions or experience with current stuff out there? I'll try and see what kind of budget we're working with.
Here's a link of one he's looking at:
http://www.circuitcity.com/ssm/Onkyo-Home-Theater-System-HT-S790/sem/rpsm/oid/148967/rpem/ccd/productDetail.do
Thanks for your help.
Sony 57" WS HDTV
Denon 3805
Denon DVD-910
Monster Power HTS2600
Rti8 - Fronts
Csi5 - Center
Fxi3 - Surrounds
Rti4 - Rear Surrounds
SVS 20-39 Pci
Denon 3805
Denon DVD-910
Rti8 - Fronts
Csi5 - Center
Fxi3 - Surrounds
SVS 20-39 Pci
Post edited by MaC03 on
I would just get the Onyko great starter system. Only problem no Hmdi.Everything I own burned in the fire!!!!!!!!!!
They have a couple at CC with HDMI at pretty good prices. My older brother has the one in the link, and it works really well for HT if setup correctly (I'm jealous as he has the perfect room for HT so his system sounds nearly as good as mine for movies. . . not music, tho).
For under $500, you can't go wrong with that package. If he's willing to spend a little more, I think they have one with an HDMI receiver and an HDMI progressive scan DVD player included. . . maybe like $700, tho.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I would highly recommend the Onkyo 790 if all your brother wants is a HTIB.
For the money Onkyo 7xx systems are very hard to beat. I have used the 770 (an older 6.1 model) and was very happy until I was ready to move up in $$$ and sound quality.
The receiver you get with the 790 is a repackaged Onkyo 504, if I am not mistaken, a very nice 20 lb receiver. In fact I am still using mine with Polk RTi's and a Mirage S10 sub.
You can probably find a slightly better deal on it online - Crutchfield.com for example.
HDMI in a budget receiver is a controversial topic, and is more a matter of personal preference. -
The guy never asked for an hdmi reciever. And unless you want everything running through your reciever and have an HDTV, it doesn't matter.
I had the onkyo 770, its the best system I heard for a HTIB for 500 . The first thing I upgraded was the sub. Anytime the bass would hit real hard, a loud thump could be heard from the sub after...
If I were him though, I would start at least with the R series. With how cheap they are nowadays, and might be just a little more than the HTIB, and sound MUCH better.AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
check out frys...
r-300 $50 a piece
http://shop4.outpost.com/product/4965501?site=sr:SEARCH:MAIN_RSLT_PG
It says only 2 for customer , but you can easily get around that...
csi-25 $70
http://shop4.outpost.com/product/4463996?site=sr:SEARCH:MAIN_RSLT_PG
So your at $270, now you just need to find a reciever...
http://harmanaudio.com/search_browse/default.asp?sp=S&brand=HK
You can find something here, we'll just say the avr230, an older reciever with only 6.1, but he will only use 5.1 anyways .
197
and lastly the sub...
http://shop4.outpost.com/product/3435193?site=sr:SEARCH:MAIN_RSLT_PG
psw303-150
never heard this sub, but for his system, good chance it will perform much better than the onkyo HTIB.
total=$617
get some cheap cables and your grand total would be around $700. Much better system especially with music.
Now it took me 5 minutes to find these components. Do your own research, and take a look around before buying. But if you just want, one, easy purchase, go to circuit city and buy it. It doesn't come with a dvd player though...
EDIT: I just to a look at shipping ands its pretty pricey. To ship all the speakers to my house would cost $150...AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Look at H/K. My buddie just bought there CP25 for his girlfriend and it sounds pretty good. Comes with the AVR235, 6 sat. speakers, the center and a 12" sub,and a DVD player. The cost is around 800.00 but I was impressed with sound for a HTIB.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
Thanks for all the suggestions. HDMI isn't an issue at this point, he doesn't have a tv or DVD player that would support it.
Ok, so it sounds like the Onkyo would be a good set.
One other way we we were thinking is to just get speakers for now. He has an older Sony that would at least do 5.1 I think. So something like this?:
http://www.circuitcity.com/ssm/Polk-Home-Theater-Speaker-System-RM6750BK/sem/rpsm/oid/124847/catOid/-12950/rpem/ccd/productDetail.do
This set is 100 bucks cheaper than the Onkyo set but doesn't come with the receiver, but do you think these are better speakers? I don't know much about Onkyo's speakers, I know they make great receivers.
I don't think that going the independent route with the R series would fit in the budget, but it's worth looking into.
ThanksSony 57" WS HDTV
Denon 3805
Denon DVD-910
Rti8 - Fronts
Csi5 - Center
Fxi3 - Surrounds
SVS 20-39 Pci -
That polk audio speaker set is a nice starter system and will play pretty well with an HK avr.............My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
