Drop in tweeter replacement?
jakelm
Is this the tweeter than can be replaced with peerless without any modifications?
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Post edited by jakelm on
yes.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Sort of. It'll work, but the crossover is slightly different for the peerless.
Guess I should have said that it's a perfect physical fit. I've made that swap before with a pair of RTA12B's and found it pleasing.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
I thought so... What series crossover does it use? Monitor 7 revised?Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
The SL1000 was used in most of the early Polk speakers including SDA's but as mentioned in the schematics thread, not all of the schematics are available because some were stored away like nuts in their noggins. If you are seaching for these schematics the best you can do is look at the ones with different values before those noted with SL2000 tweeters. Some vintage brochures are here http://polksda.com/srsad.shtml
