Hum with Coax Digital cable
izafar
I have been having ground loop hum problems in my system for a month now. I tried debugging by removing the usual suspects i-e Cable, Dish & subwoofer connections. None of these solved the issue. Last night I get frustrated and started removing all connector from my AVR. The hum disappeared when i removed the Coax Digital cable coming from my DVD player.
Has anyone ran into similar issue and what would be the best way to solve this. I can think of two options, i-e either use a TOS Link digital cable or use a ground loop isolator. So far I am inclining on the first one, as I am not sure what would be the impact of using a ground loop isolator on a digital link, i-e will it change jitter properties of the link
-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
Post edited by izafar on
Jensen CATV Isolator for Cable. Don't think this will for work for the DISH though. Does your receiver\TV have HDMI ports on it? If so, get rid of the Dig Coax and run your Audio & video thru the receiver via HDMI.
You could try a cheater plug for the DVD player as I have heard others have had success with it. Look in AVS for the cheater plug.
Good luck -
Switching to optical is a good way to troubleshoot this problem.HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee -
Try another rca cable you've got laying around first to make sure you don't have a defective cable.
I also noticed that same problem few days ago. The digital coax was causing a hum so I switch to toslink cable and it went away.
I don't know why its causing that. But I have lots of cables crossing each other.
I just wanted to enjoy music so I did not investigate more.
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35 -
I will get a toslink cable today and check it out-izafar
