Strange wiring idea (think it might work?)
karpiel666
karpiel666 Posts: 173
A few weeks agao the LFE output on my avr 5700 went funky, started sending a loud "thud" to my svs every time a signal was changed (switching sources, changing channels and navigating dvd menus). I tried all the things that people on different forums reccomended, nothing worked. So I hooked the svs up using high level inputs. Works great, but I want my mains and my subwoofer delivering the bass. Can anyone see any danger in hooking up the L/R preouts to the L/R inputs on the svs with the speakers hooked up to the 5700 using normal speaker cable?
dvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung
Post edited by karpiel666 on
  • Schwingding
    Schwingding Posts: 363
    edited November 2006
    Sounds OK to me. Email SVS tech support if you're concerned. You didn't ask for comment, but why would you want both your mains and your subs producing the same freqs? Double bass - and only half of it done well.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
