Need help with sub-woofer hook-up
kakwright
kakwright Posts: 1
edited November 2006 in Speakers
Hi there - We are trying to set up our own "home theater" with what we have. Already in place are two in-ceiling speakers toward the back of the room which I placed in "B" speakers on our older Fischer receiver, and two bookshelf speakers which I put in the "A" speakers on the receiver. I was told I need a sub-woofer which could go anywhere in the room on the floor, but I cannot figure out where to put its wires on the receiver. Can the "A" inputs share more than one wire? Does a sub-woofer even have the typical speaker wires? As you can see, we aren't very knowledgeable in this area. We aren't after perfection, just a fun sound while watching a good movie. Thanks in advance to anyone who takes pity and responds. Kath
Post edited by kakwright on
  • louthewiz
    louthewiz Posts: 581
    What you will need is a sub with speaker inputs and ouputs like the one in the picture below so then 1 set of wires go from the fisher to the sub and from the subs speaker level output you will attach the bookshelf speakers and that is the proper way to set it up................
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-631
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-633
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • louthewiz
    here is the picture so you can get an idea
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
